Thames Sailing Barge Stuff
Home › Forums › Sailing Models › Thames Sailing Barge Stuff
Viewing 25 posts - 376 through 400 (of 799 total)
  • #83670
      Hi Eddie,
      Yes a great day on the water, we were lucky with the weather & wind, the AMBO crew are a good bunch and very easy going, the Buggy/Barge transporter is a great idea looking forward to the finals at Bluewater.
      Hans talking to Robert and Dave Watts concentrating in the back ground, with you relaxing between races.
      Edited By Ray Wood 2 on 02/09/2019 08:48:06
      #83834
      Eddie Lancaster
        @eddielancaster
        Three wise men, or Last of the Summer Winelaugh.
        Peter Simmonds nearest the camera, Richard Chesney and Ray Wood on the end, racing in the 30" TSB class at Bluewater today, Ray came away with a handfull of prizes. I came last in all my races but it was still a good day, very warm with light winds and good company.
        Eddie
        #83850
          Hi Eddie,
          Two wise men Peter & Richard, and one who needs to lose a few stone, diet started today
          Takes patience to sail at Bluewater as the wind is so variable !!!
          Enjoy Broadstairs this week,
            #83852
              @timrowe83142
              Ray
              Congratulations on your haul of trophies. When is the first international regatta planned? Here in Mallorca of course!
              A lovely sight those barges and definitely on my build list. I seem to have gone off aircraft for a while.
              Tim R
              #83854
              Eddie Lancaster
                @eddielancaster
                Hi. Ray nice photo of the two boats, sorry about the caption of you three skippers, couln't resist itcheeky.
                Management is going to hairdressers tomorrow that means Roger and I can go to Hearne Bay for a mornings sail, then to Ramsgate on Thur. with the Tug, and a final morning at Ramsgate on Sunday morning before travelling home.
                Going across the wind the boat just goes sideways, I cannot get any foward drive to get the keel working, anyone any suggestions? even if it's the cr – -p helmsmanblush.
                Regards.
                Eddie.
                #83856
                  Hi Tim,
                  Trying to keep all the balls in the air, just received a couple of FMS 50mm fans from George at 4Max to build a Tony Nijhuis Jet Provost which was a recent free plan in RCM&E
                  Eddie,
                  If the winds coming directly from the side, your main sail should be let out to 45 Degrees and you will be broad reaching, that should work
                  If you had a separate vang control you could let the sprit out slightly aswell.
                  tomarack
                    @tomarack
                    Hi Ray,
                    congratulations !!!
                    the only competition I took part in was the Moravian Cup in the footy category, in Trinec town. I was not doing well, the weather was bad.
                    >**LINK**
                    My sail number is 19 , a bigger sail nr 17 is borrowed from a friend Zdenek,
                    practically the wind wasn't blowing until the last race .. and only about 10 minutes ..and then again almost windless..
                    as I mentioned, I'm starting to build a Piscataqua gundalow, scale 1:24, length 91 cm,
                    see: **LINK**
                    Greetings
                    Tom
                    #83859
                      @timrowe83142
                      Ray
                      I am going to stop trying to keep up!!
                      Eddie
                      Expanding on Ray a little bit, it sounds like you are over-sheeted. The wind coming from the side should be the fastest point of sailing. The sail position on a reach (wind at 90 degrees) should probably be out even more than 45 degrees especially in light winds when the apparent wind will not go forward too much.
                      The trick is to just have the luff of the sail full. If it flutters the sail is too far out and if over sheeted the sail stall and stops producing lift (drive) and the drag goes up a lot.
                      In the real racing world people tend to relax on a reach and a run but the winners will all be constantly trimming their sails.
                      Tim R
                      #83863
                      Eddie Lancaster
                        @eddielancaster
                        Hi. Gents, thanks for your help, I think I will try to improve my sailing with the boat as it is, other than reducing drag, I will then try another servo to control the sprit.
                        Thanks for your help.
                        Regards.
                        Eddie.
                        #83864
                        tomarack
                          @tomarack
                          Hi Eddie,
                          do it as Peter Simmonds has on his Veronica. I have it on my Tomcat anyway – and without any problems-
                          the double sheet.. for Mainsail,single sheet for Vangs.look at the picture 17/06/2019 19:38:25
                          Greetings
                          Tom
                          #83865
                            Hello Tom,
                            The Footy yachts look like fun to race 😀 Peter Simmonds told me yesterday he had just finished a Stumpy sailing barge but would not be a racer, your Gundalow looks similar, good luck from the UK and keep us posted.
                            Best wishes Ray
                            #83869
                            Eddie Lancaster
                              @eddielancaster
                              Hi. Tom, nice to hear from you again, I have my sails rigged as you suggest,it is my sailing technique that I need to improve. Sailing alongside others with similar boats soon shows up your own deficiencies.
                              Regards.
                              Eddie.
                              #83879
                              tomarack
                                @tomarack
                                Hi Gents,
                                Footy is a small model, and quite sensitive to control.
                                I had trouble driving on a distant buoy, much like last year with Capricorn at the regatta. I thought it was how the sun shone in my eyes. Finally at home I found out that I would have to wear my glasses for distance…(translated by Google).
                                I'm putting together the necessary equipment for Gundalow. To control the sail I will use again the HS 765HB lever servo, the classic rudder servo, ESC from HK. Mini motor DC12V (servomotor from the car, perhaps from the windows control). Meanwhile, I'm thinking how to continue building . Gundalow has a flat deck where cargo was carried, a difference from TSB. I need access to the hull, so I will do it just like my TSB models.
                                The difference is that I cover the coamings best as a load of wood.
                                An interesting article about gundalow you can find here > **LINK**
                                Building a gundalow replica "Piscataqua" =>
                                Greetings
                                Tom
                                #83957
                                  Took a trip up the London on Saturday to have another look round HMS Belfast and be tourists for a day with my wife and 2 of the older grandchildren, Spotted tsb Will moored slightly up stream in the Pool of London, almost makes me want to build another one !! but not yet
                                  #83958
                                  Eddie Lancaster
                                    @eddielancaster
                                    Go on,you know you want tolaugh.
                                    Eddie.
                                    #84137
                                    tomarack
                                      @tomarack
                                      Hi,
                                      autumn in the park – I took advantage of the very warm weather and went to try the tomcat in the park (while there is still water in the pond).
                                      after about half an hour the model stopped responding – I did not measure any battery voltage. Only then at home did I find out that it was a 1A fuse .. bad luck .. Next time I take more fuses with me.img_1865.jpg
                                      #84193
                                      tomarack
                                        @tomarack
                                        Hi,
                                        I put the photo once more
                                        #84194
                                        tomarack
                                          @tomarack
                                          Hi, I have
                                          a new blog about Piscataqua River Gundalow, but here.. **LINK**
                                          more info you can find at FB too, where is blog > Model Thames Sailing Barges and brand new blog
                                          > AMBO ( The Association of Model Barge Owners )
                                          (  https://www.facebook.com/groups/2659272094133382/
                                          It's such a replacement for> modelbarge info
                                          Richard Chesney said he had no time or opportunity to maintain the original site.
                                          it's a shame, we lost a lot of articles and information about TSB models
                                          Greetings
                                          Tom
                                          Edited By tomarack on 18/10/2019 15:27:40
                                          Edited By tomarack on 18/10/2019 15:30:34
                                          #84482
                                          tomarack
                                            @tomarack
                                            Hi Ray,
                                            I saw your Veronica in nr 12 –
                                            Model Boats Magazine ,, congratulations !!
                                            I have currently glued deck planks on gundalow, I managed to make the deck like at the very old boat ..
                                            Greetings
                                            Tom
                                            Edited By tomarack on 16/11/2019 15:45:10
                                            #84499
                                              Hello Tom,
                                              I haven't seen next month's issue of Model Boats yet but glad Veronica is photographed at Headcorn show by Kim we had a good chat 😀 Also my White Marlin is the free plan, I hope you like the article.
                                              tomarack
                                                @tomarack
                                                Hi Ray,
                                                I got a lot of documentation and good advice from Kim when building my barge models. He is one of the few who really selflessly advises (I have to mention at least Peter Siímmonds and Richard Chesney too , and next modellers from this forum.)
                                                t's a pity that Kim articles on> Modelbarge info <are no longer available. Very interesting and helpful.
                                                White Marlin .. interesting article, indeed ! I got an older polystyrene model hull with deck (ca 50 cm long), so I just need to make a superstructure. But I don't know what ..
                                                Greetings Tom
                                                #85446
                                                tomarack
                                                  @tomarack
                                                  Hi,
                                                  I am slowly building the Piscataqua River Gundalow. today I tested rigging settings. But I still have a lot of work to do – finish spraying the hull, rudder, engine, electronics, fin with a lead bomb of about 850 grams ..
                                                  Photos are here on the album or on> **LINK**
                                                  #85464
                                                    Hello Tom,
                                                    The rig is good and simple with the single sail, rather like our Norfolk Wherries, our sailing barges are in hibernation, but must start preparing for the new season soon 😀
                                                    All the best from the UK
                                                    Ray
                                                    #85596
                                                    tomarack
                                                      @tomarack
                                                      servos and main horse in placeservos and main horse in place
                                                      the construction of the model slowly continues. The worst thing is finishing the model and details. greetings
                                                      Tom
