Bilge Pumps
Bilge Pumps
Home › Forums › Beginners › Bilge Pumps
  • #128415
    Queequeg Quint
      @queequegquint38270
      Is it a good idea to install a bilge pump into our boats? On the one hand, it seems like a good safety feature. On the other hand, I’ve heard that professionals don’t use them and they just focus on making sure water does not get into the boat.
      #128416
      Len Morris 2
        @lenmorris2
        The short and simple answer is no (and I’m definitely not a professional).
        Some water will always get into the hull after a days boating, up the prop shaft, linkage outlets, open decks etc.  It’s easily dried out at home.  If it’s serious enough to need a bilge pump then I’d look hard at the boats design or consider model submarines.
        Len. 🙂
        #128419
          I have to agree with Len, a bilge pump should only be necessary in very exceptional circumstances. The whole principle of a boat is that the water stays on the outside!
            One of my pet quotes all my life has been: “Don’t deal with the effect, deal with the cause”.  This is a perfect example.  The problem with adding a bilge pump is that you will slide into a state of mind that then accepts leakages as normal and acceptable, then one day the bilge pump fails.
            I work on the principle that water in the hull indicates an issue that needs identifying and rectifying.
            #128467
              @timrowe83142
              This reminds me of an an argument I used to have with my boss with I was a pattern-maker in a GRP production factory.  He would tolerate damage to a mould that required re-finishing on every product. To be fair, a small scratch in a mould translates to a fine ridge in the moulding which is quite easily rubbed and polished out but a lot of scratches is a lot of polishing and wates time and money.  The other problem is that polishing leaves a different surface texture to the contact moulded surface and this can show up in varying light conditions.
              The laminators had the phrase “Mould is King”.   Because the plug is a male feature and the mould is a female feature they also had a nickname which is quite unrepeatable here!
              Tim R
