Hi all.
Been hard at work, and have cut out the side panels.
I'm kit setting the hull at work, and then I'll take the parts out to my friend Lynn's place, (where I stay at the weekends) to assemble her. (The boat that is). Although I managed to negotiate building model boats in my spare time at work, this one will be very much in the way.
I took the side panel patterns off the half model before cutting it up. I then traced around my card pattern, and dimensioned it.
The vertical lines are the frame spacings, measured from the bow. The lower horizontal line is the sheer, the upper the chine. the sloped line is the transom.
this is transferred to the 7mm radiata pine ply.
The upward sweep in the chine at the transom is the result of carrying the width well aft, then quickly sweeping in to a narrow transom.
Scaling off a half model isn't super accurate, and a few errors showed up, but they were obvious, and the plan was amended to suit.
Due to the length of the sides, two joins were required.
This is my preferred method.
All the three panels are laid out end to end, but over lapping by a few inches and marked. The side pattern is then drawn out. A straight datum line is struck down the middle of the panel. The sheets are then separated, and the panels cut. One side is then used as a pattern for the other. The panels are then laid back together end to end and over lapping. A wiggly line is then cut down the length of the overlap with the jig saw.
The panels are then joined together with a butt strap of the same plywood behind.
(Making sure the datum line is straight of course!)
This method gives a much stronger and fairer butt joint than just a straight joint would.
The first frame made up off 3/4" ply. (used to be my bench top, don't tell the boss!)
All the frames will be made in two halves, for economy and easy transporting. The joins are cross halved, but not yet glued.
These ply web frames are strong and light, just the thing for any boat with pretensions of planing.
Amy j
Edited By Amy jane September on 15/08/2015 09:14:36
