All my visitors have now left so I am back in the boatyard AKA the dining room! I collected the winch and rudder servos from the component shop at Ally Pally and fitted them into the hull, using screw eyes temporarily to check the run of the winch line, they will be replaced with pulleys when they arrive from Poland.
the mast step has also been fitted.
I have also made all the mast fittings.
The mast is 10mm. aluminium tube from B&Q. I think on reflection I should have used 12mm. but as there is no mention of size on the plans I went for this size, I think it should be strong enough as the sails are not that large for this size of boat.
The fittings slide onto 8mm. tube which is a slide fit inside the outer 10mm. tube, the mast is then made in sections to get the height required, I will post a photo of that when it is finished.
I know this may not be true to scale but I want a boat I can sail and have fun with, not to exhibit, I can always go down the scale route at a later date if I need to.
Edited By Eddie Lancaster on 30/01/2018 12:58:32
Edited By Eddie Lancaster on 30/01/2018 13:00:10
