Hi Folks, it's nice to read your comments about how you set about building and what you use, very helpfull to a newby boat builder.
As I am still house bound and having finished the construction work on my Grandsons boat, (it just needs painting) I have started to look at my next project, the Ardent, I have put together an order with SLEC, thanks for that Ray.
The next job will be to get the frame drawings onto the ply, having looked at all the usual methods I have come up with the following,and any comments would be gratefully received.
The frames are drawn half section so they would have to be flipped over to get the full frame. This hull has a double chine and all the lines between the keel and the first chine is a straight line as are all the other lines on the outside of the hull frames, the only curves being the top of the cabin, which I can get from the roof frames, and the cutouts to the inside of the frames.
As the frames are drawn with a centre line and a water line at 90 deg. I intend to use these as vertical and horizontal datum lines and to take measurements from these and draw directly onto the ply all the points of the frames and then simply connect the points with a straight edge,at the same time extending the frames up to a another datum parallel with the water line so that I can attach them to a building board upside down, as you have done Ray.
Can anyone see any flaws in this that I may have missed?
Regards Eddie
