Hi everyone! I was wondering if anyone here could possibly give me any clues as to the rough age and possibly make/model of a boat that my grandfather and I used to sail.
All I can really say with regards to its history and setup is that it was originally fitted with a little single cylinder internal combustion engine, unfortunately when we acquired it, upon inspection of the motor my grandfather discovered that the crankshaft had snapped and caused damage within the engine. It was also fitted with a rudder system that although technically steerable, it was non RC at the time. The steering system consisted of a tiller arm on top of the rudder shaft that connected to a little toothed bar, so it was logical to assume that before launching the boat onto the water you would set the rudder at the desired position angle and off it went across the water.
Due to these systems and the desire to make it RC my grandfather and I retrofitted a servo reciever motor and necessary hardware to convert it so some modifications and adaptations had to be made both internally and externally. With regards to the outside, you will notice the boxed sections in the rear deck area, these are non original and were designed and built by my grandfather to house some of the various hardware. Internally there were obviously numerous brackets and box sections added to mount running gear and the battery. Pretty much everything else bar a few deck details is original.
If anyone is able to shed any light as the the age and make/design of this model that would be amazing! All I know is it is very very old but also very well made and gave many days of enjoyable sailing.
Craig
