Brutus
Brutus
Home › Forums › Scratch build › Brutus
Viewing 25 posts - 151 through 175 (of 1,017 total)
  • #46167
      Shop floor to top floor
      You'll swoon with shear delight, when you see it!
      I'm on a roll now
      The formers are taking a lot of time and effort…..3/8" ply takes some shaping!
      Pictures in about one hour!
      Ha! ha! Ha!…..(.Insane laughter)
      Bob with arms going like Bee's wings!
      #46168
        Here we go, Paul
        All the formers located on a central spine!………Like it?
        The first set of pictures show work in progress, with the semi finished formers roughly in position
        More following…
        #46169
          Cracking idea Gromit
          I like the spine its a brilliant concept………..wish I had thought of it.
            This set of pictures show the formers with temporary stringer material roughly in position, to show Paul how it will look eventually
            The keel will be fitted as soon as the formers are finalised
            What`s the verdict, Paul?
              Looking good to me Bob but I will be a lot happier when the keel is in place.
              #46172
                Thanks Paul
                Need to know how the stringers meet the keel prow, please
                  Hi Bob
                  Remember those instructions that I sent you……that you said you wouldn't need, lol
                  There are two horizontal frames in the bow that take the place of the stringers, you will find them on drawings 9 and 10
                  Edited By Paul T on 08/01/2014 11:21:45
                  #46179
                    Thank you Paul
                    Can you show the transom in position, please
                    Is the keel flush with the top of the formers….ie….No keel?
                    Should have the keel on by tea time
                    Just got in from a campervan trip to Etherow……Very mild today
                      Lovely looking work Bob.
                        Thank you, Colin
                        I am enjoying the build, as the finished result is a complete mystery at the moment
                        We are expecting to be surprised with the performance…….Hopefully
                        I am impressed with Paul's CAD skills, especially predicting the former shapes and associated calculations
                          Hello Paul……You can stop worrying now!
                          It all fits together ok……But I don`t really know how the keel and formers should be?……The keel is almost flush with the hull surface?…….I think you`ve just sent me a cross section, I`ll have a look
                          The transom has a very sharp pointy bit……..Does the keel match it with a filler strip of some sort
                          To be honest it`s a bit too early to be asking these questions
                          Study the pictures and report back?
                          The first picture shows how the keel is almost flush with the hull bottom….ie……No keel?
                          The third picture shows the transom pointy bit, as mentioned
                          Anyway, Paul……..The build is great fun!
                          Bob….R & D Dept
                          #46187
                            Hi Bob
                            It looks very good and everything seems to fit as intended.
                            No keel showing but the keel timber will have to be shaped at the bow and stern to suit the hull profile.
                            The flat top of the transom fits flush with corner (straight meets curve) on the aft end of the keel.
                              How about this fairing for the transom crest?
                              #46196
                                Hi Bob
                                I'm sorry Bob but I didn't make this connection very clear on the drawings as the pointy bit of the transom fits flush with the base of the keel and the two stringer cutouts are for the deck stringer.
                                The keel to the rear of Frame 7 has to be shaped to accept the curved skin so the keel stringer will almost disappear.
                                  The depth of the transom pointy bit is about 1/2" deeper than the land on the keel
                                  Send a picture worth a thousand words!
                                    You are right (as usual) the pointy bit is 12mm lower than the keel. The following image shows the relationship of F7 to the Transom (in red).
                                    Sorry for missing that detail Bob, my excuse is that I am busy working up a set of sketches for a nice chap who wants to build a multi hulled, sea axe style futuristic warship (project Triton) currently the rough design is 2m long  and 0.5m at its widest point
                                    Edited By Paul T on 09/01/2014 14:23:09
                                    #46202
                                      2M long!……..Wow!
                                      So….Is there a filler strip in front of the famous pointy bit?
                                      I`m working on the Upper and Lower horizontal panels
                                      Upper seems ok
                                      Lower……If it`s supposed to line up with the stringer height…..Then the tenons are too wide
                                      Picture to follow
                                      Can you see what I`m on about?
                                      Note, I`ve taken some weight out of the middle….We need the rim for clamping the ply
                                      Edited By Bob Abell on 09/01/2014 15:09:39
                                      #46203
                                        Hi Bob
                                        2m is the reduced version but not to worry as knowing the client has a restricted workshop the model will be designed to split into four pieces.
                                        No there isn't a fillet piece as the transom and skins have to be 'worked' together, its a difficult detail as the transom is so slender but it should look super when finished.
                                        The lower horizontal panel should line up with the chine stringer cut outs so please trim the tenons to suit.
                                          Drawing Office to Shop Floor
                                          I have just had the MD on asking why I was playing around with futuristic warships and not writing up the Brutus building instructions.
                                          But when I explained who the client was and how much he wanted a statement piece for the next Haydock show I was given the nod to continue so the instructions might take a couple of days whilst I sketch up this Trident project.
                                          The hard working designer is having his tea now.
                                          #46211
                                            That's very flattering, Mr Chief Engineer, sir
                                            But don't you go working too hard!…..There's no need to over exert yourself
                                            I've got my hands full at the moment, as you know
                                            Sounds very exciting though!
                                            I think a 3D illustration would be nice to look at first?
                                              Shop floor to him upstairs!
                                              The upper and lower panels fit ok, Paul
                                              I`m clockin` off now
                                              #46250
                                              Amy jane September
                                                @amyjaneseptember49770
                                                You're really flying along there Bob, A nice work shop, plenty of time, I'm sooo jealous!crying
                                                #46253
                                                  Thank you, Amy for your kind comments
                                                  Finally got the structure set up to my engineering satisfaction!………lol
                                                  Everything lined up and dead square etc……..Note the steel rule clamped to the spine, to eradicate any bowing.
                                                  The problem now is that I`ve not used the glue yet!
                                                  Can`t possibly dismantle it all, so I`m going to "Tack weld" all round with glue seams and reinforcing where necessary with balsa strips
                                                  #46254
                                                  Andy C
                                                    @andyc56856
                                                    Looking good Bob. I like the holes in the frames for added lightness. Was that done with a router or drill and sanding?
                                                    Andy
                                                    #46255
                                                      Hello Andy
                                                      Thanks for your comments
                                                      Cutting those slots out was quite a big job, in 3/8" plywood too
                                                      I drilled a hole at each end then cut the slots out with a fretsaw and cleaned up with a file
                                                      Can't see them doing much good, but they do look technical?
                                                      Now in the process of applying the glue
                                                      I'm really enjoying the build
