which motors? suggestions appreciated
Home Forums R/C & Accessories which motors? suggestions appreciated
  • #39206
    captainslog
      @captainslog
      Hi allsmiley thanks to sammyk I can now fill in the faded/ missing parts to the stalwart plan no, 264 by David Mann. the motors I require are old models. the prop shaft driver is a jumbo550. looking on the web that was a graupner 540 with an extended body and higher torque than their 540 model. motor 2 is a decaperm geared at 2.75 : 1 with 2 stages of 3 : 1 reductions driving the rear axle. I foned mfa como for advice and to be honest he hadnt heard of DECAPERM !!! and could not help.a few model shops later and i was told 1 would cost £150. At that price I may as well use the july 2011 build, and use the graupner water jets. The idea of this project is a present for my old man and not an absolute scale project. The plan is close enough for me as I have many photos of scale detail to add to the basic design. could anyone please advise on the equivelent motors I could use and purchase new at reasonable cost? ( total reduction for the decaperm is 24 :1 and the original set up was all driven by 12v) sorrwas long winded but I needed to explain my situation and drive systems have many variables. thanks keith
      #5210
      captainslog
        @captainslog
        stalwart build
        #39211
          Keith
          Component Shop stock the Mabuchi 555 motor which is a low RPM + high-torque 12v motor and may well substitute for the Jumbo 550 type. At nine quid it has to be worth a shot. For the Decaperm substitute I'm surprised MFA Como didn't suggest one of their geared Torpedo 500 types – also stocked by Component Shop at twenty pounds.
          Telstar
            @telstar
            Hi Keith
            The Dacaperm 12v has a no load speed 8,400 rpm geared output 3,000 rpm .
            No load current 0.3A full load 3.5A rated @ 20w
            This info is from a Decaperm leaflet unfortunately written in German.
            This info may help you select a alternative
            Cheer Tom
            #39249
              MFA geared motor specs here (there's a PDF table to download with all the shaft speeds for various gear ratios and voltages) **LINK**
