What motor ??
What motor ??
Home › Forums › R/C & Accessories › What motor ??
  • #61376
    Andy Hustler
      @andyhustler32076
      going through my many boxes of odds an sods and have found a large electric motor that i cannot rember buying or how it got in my collection .it's from a comp[any called Samprop Electronic and it says on the casing Power Speed 660 so what sort of speed isxit ? a fast one or a slow and steady ?/ Also i've found another no makers name or anything just numbers and letters 65350 3C4152 5.5cm long (just over 2 inches ) by 3.5 cm across ( 1 and 1/4 inches ) across so folks what are they for ????
      #5392
      Andy Hustler
        @andyhustler32076
        #61383
        Charles Oates
          @charlesoates31738
          Hi Andy, It’s a high power high amp high reving motor. Colloquially known as a big bbb, beggar!
          It’s worth using google, lots of results on there.
          Chas
          #61411
            If the words "power" and "speed" appear together on the makers nameplate, I would take that as a clue. You can get further clues by holding the shaft and rotating the can a full circle, counting the number of notchy feelings you get. Divide by 2, when you get 3 as the answer, it is probably a fast one. If you can see the windings through the vent holes, if the wire looks like hair, that is a low current motor, if its like baling wire, another sign of a high power high current device.
