What charger ?
What charger ?
Home › Forums › R/C & Accessories › What charger ?
  • #64554
    Associated
      @associated
      Just ordered myself a lipo battery and il need a balance charger and discharger in one . I have done lipo charging before so know a little bit about it . What can people recommend?
      Thanks
      #5415
      Associated
        @associated
        #64563
          Hi Matt
          The easiest and safest way is to use a charger recommended by the battery manufacturer. Have a quick goooogle at their website and see if anything is said.
          Dodgy Geezer 1
            @dodgygeezer1
            On the other hand, if you are a 'cheapie chappie', there are no end of iMax B6 clones on ebay. Lots of features and they cost about £12 – 15 there. I've used one for years, found it works well, and haven't blown anything up.
            Yet.
            (Note: Claimed lack of explosive tendency only refers to battery charging actions conducted with the iMax. It does not cover any other electrical or chemical activity.)
            #64570
            Associated
              @associated
              Would always charge a lipo in a charge bag for safety reasons . There are so many chargers out there !
              #64571
              mark69
                @mark69
                Hi Matt have a look on the Hobbystores.co.uk (Ripmax) website they have a few good chargers which can Ballance and cycle ! not badly priced ! I buy most of my stuff there hope that helps……..mark
                #64572
                  Hi Matt
                  You know what its like trying to get the right spare parts for the local authority equipment that you maintain. Nearly right just doesn't work no matter how cheap the part is.
                  Which lipo battery have you bought?
                  Associated
                    @associated
                    One of these Paul …
                    Andy C
                      @andyc56856
                      Hobbyking do a turnigy charger for £16 too, does lips and all the other types as well. Seems good value.
                      Andy
                      #64581
                        I think that it's rather wide of the mark to 'recommend' something unless you actually have used one. I have used the Accucel charger for LiPo packs on the Component Shop website and it's very good. Shame they have no stock at present, but that in itself should indicate something positive.
                        Associated
                          @associated
                          You can get the same charger from eBay too , £28 I believe, HK is cheaper but with postage wouldn't be far from the eBay price .
                          #64590
                            Matt
                            Not being proficient in the use of lipo batteries I would recommend that a telephone call to Hobbyking customer services as the best way to locate a compatible charger, this method has the added benefit of if something goes wrong you can take it back to the supplier.
                            Cheap isn't necessarily value for money.
                            Associated
                              @associated
                              Paul it's a turnigy charger so was going to go for same make charger
                              #64605
                                Hi Matt
                                Sounds ok to me but I don't know much about this new fangled electricky as I'm more of a petrol head. I imagine that if you buy from a reputable source then there should be less chance of buying a cheaply made copy.
                                You get what you pay for……Buy cheap and buy twice….and all of the other smart ar–d comments.
                                Associated
                                  @associated
                                  Be nice to see how would you fit a petrol engine in a boat like this
                                  Never seen close up how engines are fitted and they seem a lot of money .
