Waterproofing electrics
Home › Forums › All things floating › Waterproofing electrics
  • #55621
    Geoff Sleath
      @geoffsleath41411
      I came across this video via the RCMF forum. I'm subscribed to Flite Test but I somehow missed it myself. It's mainly to protect servos, receivers and esc from water ingress in float planes or from wet weather flying but it has as much, if not more, relevance to model boats.
      The only problem is acquiring the products in the UK but other comments on the RCMF thread found this:
      http://www.rccarshop.co.uk/index.php/rc-accessories/lazy-goo/corrosion-x-waterproofing-solution.html
      Although it's currently shown as out of stock an internet search might help. I think I'll certainly look into it for my barge. I know my 1 metre yacht hull seemed to spend quite a lot of time submerged in a blow and it was better waterproofed than my scale barge is likely to be.
      Geoff
      #4185
      Geoff Sleath
        @geoffsleath41411
        #55633
          Geoff. We had a discussion regarding using sandwich boxes and all sorts, to waterproof electrics, but the majority opinion was it was best to make the effort and keep the water out in the first place.
          Unless stuff is actually on the hull bottom it is unlikely to get wet enough to drown it all. I would simply arrange for the gear to be mid-hull or on top of the batteries and not bother with fancy kit.
          Ashley. Usual disclaimer..personal view and so on.
          #55639
          Mark Jarvis 2
            @markjarvis2
            Hi Geoff
            Ash has a point of keeping water out in the first place, but we all know it happens, my tug ha a small leak but only between two bulkheads, guess were my stering servo was.
            Waterproofed the replacement servo with a plastic glove, (medical) until i could find were the water was coming in!!!
            Servos are damp proof, dont abuse them, however going to the hassel and cost of waterproofing them, wich is only good while the grease is intact, dont think its worth the work,
            Sandwich box from poundland some rubber grommits and a squeze of silicon sealant, top job dirt cheap.
            Mark
            #55649
            Geoff Sleath
              @geoffsleath41411
              Someone on the RCMF forum did suggest an (unused) condom as a waterproofing sleeve but, as we all know, they are not 100% foolproof .
              We used to use screw top plastic pots for the receiver and battery in racing yachts (I'm sure they still do) but at some point the wires have to come out of the pot to the winch and servos. The servos themselves can't easily be sealed in a box because of the push rods. I used to take the rudder servo apart and put conformal coating on the board (just an ordinary 148 servo) because there was always a lot of water in the hull after a breezy race because the sheets have to come out somewhere and it's impossible to fully waterproof the hull. I would think fast racing models might benefit, too.
              I was involved in designing radio telemetry systems that were subject to high G (20,000!) and high temperature (125 deg C) in aero engines so had access to all sorts of gunk at the time though I didn't go to the point of potting the electronics in epoxy as we did at work.
              I was particularly impressed with the performance in salt water after proofing because whilst pure water doesn't conduct electricity salt water certainly does. Moreover sea water is a notorious corrosion agent. I think the potential for saving electrical and electronic components following a sinking makes it worthwhile.
              Geoff
              #55650
              mike farrell
                @mikefarrell21522
                Hi Geoff. As Ashley said prevention is better than cure and to this end every boat I build I use window fitters Silicone .
                Each joint has a light smear over each joint ,it keeps rain out of windows so will keep ingress of water
                Its as cheap as you want it to be £2-3 for a tube and will last a long time if you reseal it after use.On the market is a smaller tube but at what cost £4.50 ,pretty tube but nothing more.
                All my electrics are mounted on the hull sides ,batteries raised off the deck ( failed once and ruined a 12 volt pack)
                Recently Paul Thomason showed his esc mounted over the motors .a good idea winkMichael
