Voltage supply from speed controlers to radio receiver.
Home › Forums › R/C & Accessories › Voltage supply from speed controlers to radio receiver.
  • #42135
    DOUGLAS BUSHELL
      @douglasbushell19364
      Can any one tell me what the voltage to the radio receiver be ?will it still be 6 volts ,even if the batt to the motor is 9 volts.
      As I am concerned if 9 volts is sent to the reciever it will blow it.
      Hope you can see what I mean.
      Doug.
      #5240
      DOUGLAS BUSHELL
        #42137
          Almost every BEC unit fitted to ESCs (and most separate ones) intended to power the RX and other items plugged into the RX give a closely regulated 5 volts, this being handily the de facto world wide industry standard for data chips which has resulted in such regulators being just about the most common chip on the planet.
          If you hook the RX direct to a 9 volt supply, yes it will die, as will everything else plugged into it. Pretty much anything designed for 6 volts will perform happily on a regulated 5 volts, not least because batteries lose voltage as they discharge. However, not all devices designed with 5 volts in mind will survive 6 volts, but there will usually be a mention of this in the instructions.
          #42138
          Michael Sheridan
            @michaelsheridan92093
            Does the speed controller in question actually have a BEC circuit? Not all do.
            #42145
            Kimosubby Shipyards
              @kimosubbyshipyards
              Hi Douglas,
              Receivers should ideally all be on 4.8 to 5 Volts. Yes they can tolerate 6V, but make sure that is a stable regulated supply, as a 6V battery can give near 7V when newly charged up. Small cheap voltage regulators can be bought from Action via Component Shop for example.
              Check the instructions on the ESC you are using for the voltage it is supplying (I've just looked and most do not actually tell you what the voltage is, just that it's a BEC @ 1.2A), AND remember, if you are powering the receiver via a BEC, that BEC link is also powering every other servo connected to the receiver, the rudder, switches, winches, sail arms etc. If the BEC fails (if the ESC overheats for instance) everything else goes too. That's why I "belt and braces" and either use a power board with a separate regulated receiver supply, or use another small 5 – 6V battery via a voltage regulator to supply the receiver. In that case you need to take the red lead out from the BEC plug and tape up.
              So saying, I do know some IOM yachters over here that use 7.2V small packs to their receivers and hence their winches because the winch servo [RMG] can take this voltage. They ignore the fact that the receiver might not!!!
              Kimosubby
              #42171
                It might help to understand how ESCs are arranged.
                There is the output side that feeds the motor and takes its power from the main battery.
                There is the control side that tells the output what to do based on information coming from the RX. This either gets its power via the RX, from whatever is powering the RX, or if the ESC contains its own Battery Eliminator Circuit it will power the ESC control side and offer 5 volts to the red RX lead to power the receiver and whatever else is plugged into it. If the RX has its own supply, the two will tend to fight it out. Normal practice is to disconnect the red (centre pin) wire by winkling it out of the housing and taping it back in a tidy manner in case its needed later.
                Some RXs say "BEC" on the label. This is best ignored. It rarely says what the maximum input voltage is, never says what voltage is offered on to the other items, and doesn't say what current it can handle.
                Sailwinches were mentioned – the higher voltage types often contain a BEC – they are, essentially, a speed control.
