Vintage 6m
Vintage 6m
Home › Forums › R/C & Accessories › Vintage 6m
  • #5312
    mark tinkler
      @marktinkler40928
      Conversation on vintage 6m to RC
      #50328
      mark tinkler
        @marktinkler40928
        I have a loverly vintage 6m model yacht, I would say from 1940/50s
        I am in the process of restoring her and would like to add RC.
        I am on a budget and think I need a basic two channel system – any recommendations.
        From the hardware I have I think it used Braine steering , the rudder is an un balanced 1/2 circle of brass hung off an extension / skeg of the keel. Should I convert this to a balanced rudder.
        I am not interested in racing just seeing this fantastic machine sail. I am a keen dinghy sailor and built a couple of experimental multihulls in my time.
        Mark
        #50330
          The rudder on a braine boat was usually more of a trim tab to keep the boat on a set heading and course, rather than a steering device to change course which is what is wanted on a radio yacht. Balanced or not, it will need more authority, meaning more area. A balanced one might be less demanding on the steering servo, but will probably need some serious re-siting and an extra coat of thinking and pondering.
          On a large boat, extra channels and controls to trim the sails individually is nice but not vital. 2 channel is becoming increasingly rare, given the low prices of modern multi channel sets. A 6m would need a large winch to work both sails – two more modest ones might not only be cheaper, but might make life simpler when fitting out.
          #50331
            Mark. Hello and welcome to the font of all knowledge (ish).
            Any cheap set will do to be honest. If you need more than two channels then a Planet T5 2.4Gig set is as good as anything, about £45 or do an e-bay and get a cheap second hand 27meg or 40 meg set.
            I am not a sailor but my understanding is that balanced rudders are best for powered boats, however balanced ones do reduce the forces on the tiller somewhat, Whether this makes any difference to a model is open to debate and no doubt someone will have an opinion on this. I think it may be one of those things we like to disagree on !! I have no idea personally. I would leave it as it is as it is a period feature unless it is ugly.
