Vic Smeed’s Moonglow
Home › Forums › All things floating › Vic Smeed’s Moonglow
  • #34102
      I'm putting together another Model Boats special issue which will feature classic plan features from the past.
      One of these is likely to be Vic Smeed's Moonglow which you 'can build in a couple of evenings!'.
      Original suggested power was 1.5cc to 3.5cc diesel. The model is fairly lightweight and 35 inches long and about 9 inches in the beam.
      Has anyone any suggestions on a suitable equivalent electric setup?
        Suitable electric power
        #34105
          Hi Colin
          If you are looking for something that modellers might have in their spares box then I would recommend the good old Johnson motor with a gel battery.
            I'd start with something like a Graupner Speed 600 ECO, 7.2v or 8.4v pack and a 3-blade 30mm or 35mm prop. Cheap and cheerful.
              Many thanks for the suggestions, duly taken on board!
                We could do with a little chart of thrust equivalents, old i/c or glow engines verses modern electric, as not only does this topic come up now and then, but others must convert old boats to electric on a try-it-and see basis with various success.
                Ashley. Not much use I am afraid as no old i/c boats to play with.
                #34132
                  Good point Ashley and it reminded me of the tables published in Vic Smeed's Model maker Annual in 1963 which gave very detailed technical data for all the IC and electric motors in boat use at the time.
                  I have scanned them in but the text is too small to reproduce in an album photo on here. It might be possible to publish it in the Special issue but would there be sufficient interest in something like this?
                    Have you got a picture of Moonglow, please?
                    Just for interest
                      Found Moonglow on this very interesting olde worlde website…..
                      http://www.vintagemodelworks.co.uk/?page_id=9
                      Full of other good stuff too!
                        Colin, rather than a full list, what about a rough guide as to the output in watts of a typical 1.5cc glo or 3cc whatever, and possibly at what revs (although that might not be so useful), and then in theory a similar wattage electric motor could be fitted and so the performance should be on a par with the afore mentioned smelly i/c motor ??
                        is that reasoning right?
                          When set up correctly IC don't smell…………….. they just go fast.
                          #34139
                            Paul. the smell..hmmm
                            fast is the point here…how fast … is a 1.5cc glo a very powerful beast? if so a 3.5cc must be stupendous…or is it?
                            Colin, you never know, interest may be high…but how to find out the interest? I would have thought it would be worth a page in a special devoted to older boats? see below, if using old plans.
                            I found a table, possibly by Vic Smeed, of "current" electric motors …Orbits and other exotica, in one old mag at home. very interesting if building a boat from an old plan and it says "orbit 805" for the motor…look it up and find a modern equivalent!
                            just reread the thread beginning… a table of equivalents surely is a MUST if publishing a special on old plans??
                            Edited By ashley needham on 25/04/2012 14:00:14
                            #34140
                              And just who is going to do that Ashley – are you volunteering?
                                Well done Ashley, will you be covering areo and diesel engines upto 10cc
                                #34144
                                  never volunteer for ANYTHING!
                                  Could be a mastermind subject.."and now Ashley, you have 3 mins on the subject of British tiddly engines up to 10cc from the year dot to 1960"
                                    I guess that's a no then…..
                                      Hi Colin
                                      I think its a big YES
                                      If Ashley could do a special subject on mastermind on these engines then he is your man, in fact we have forgot all about the 2 stroke engines upto 75cc so you really do need Ashleys knowlage.
                                        I can see it now "name the bearing material used on an Arbutnot 3.249cc Hi-power special from 1930"
                                        If a sheet of i/c engines was passed my way i SUPPOSE I could see if there was any generalisations one could make, and compare them to , say, the common Graupner brushed motors in terms of power…supposing the power output of the i/c engines was mentioned…but.. supposing a 1.5cc diesel and a GP500 on 7.2v produced approximately the same max power.. does this mean the performance would neccessarily be on a par when fitted to a Moonbeam skippy special boat?? or would there be other factors, like revs and prop sizes and weights that would affect the performance and so stop a simple like for like power comparison taking place?
                                        I am guessing that a 1.5cc motor and a small fuel tank is fairly light, and would out power/weight a brushed motor and Nimh battery pack AND esc???
                                        Ashley                 has no spare time as it is
                                        Edited By ashley needham on 26/04/2012 09:21:05
                                        #34166
                                        Gary Dyson
                                          @garydyson81492
                                          Mornng all sorry to go slightly off topic but while we're on the subject of power output lists has there ever been a list of motor size to prop size printed for optimum perfomance ?
                                          eg
                                          grpnr 400 7.2v = 25mm prop gives X amps draw ?
                                          Gary
                                          #34170
                                            There are recognised mpotor/prop combinations for competition classes but as far as scale is concerned it is a moving feast, there are just too many variables involved.
                                            The usual practice is to draw upon previous experience, either your own or somebody else's! If you are building a kit then the manufacturer will usually have some suggestions otherwise the best thing is to find a boat of around the same size and type as yours that works well and use that as a guide.
                                            There was an article in last year's Construction Special Issue of Model Boats which gave some suggestions on the subject.
