twin motor info
twin motor info
Home Forums All things floating twin motor info
  • #24376
    LARRY WHETTON
      @larrywhetton68737
      any body tell me howto get two motors to work on one esc please or any other way to power up lct 6 by the way glynn i enjoy plans you are my type of builder thanks larry.
      #3468
      LARRY WHETTON
        @larrywhetton68737
        #24378
          Larry
          Food for thought here
          Armando Loni
            @armandoloni78860
            Looks great, Larry. You must work fast! I hope to build LCT6, too.
            #24501
            Phil Winks 1
              @philwinks1
              Another option if you have a reasonably spec’d 6 ch computer tx you may find that the elevon mixing function will do the same thing with 2 esc’s converting tank steering to mixer steering without a mixer putting (in the case of a mode 2 tx (throttle normally left)) the throttle on the right stickup and down and steering on the same stick left/right a very easy way to operate differential steering
