  • #17691
    Steve Arendse
      @stevearendse23393
      hi ,i was thinking of doing this arrangement on my destroyer,does it handle well on a 800 mfa torpedo motor and does the motor draw alot of amps…
      #17692
        Steve, this is not a very efficient set up to run on a model.Or the real thing for that matter. There were only that many props on the Turbi in order to overcome, or lessen, the effects of cavitation (at about 2500RPM on the real thing) On yer model, even a Torpedo 800 on 12v revs at 5000 rpm, and the blades on a prop that small are not exactly.,,er, exact…so. On some early TBD boats with ungeared turbines there were two props per shaft, but this soon changed to one per as soon as the more efficient geared units came along,  Props as small as that on the pictured model turbi, and I am guessing at 25 or 30 mm have to be spun at a fair pace….(12000 rpm???) to produce max useful thrust. My Turbi has 3x30mm props of approximately the right blade shape (see my gallery)and has yet to run….I am undecided on the motor setup, and I suspect only experimentation will prove what works best, unless the owner of the boat pictured can give us a shout. It may be that with all those props indeed only 5000 rpm will be needed…who knows????      The only reason for using that many props on a Turbi model is looks, as its what makes a model Turbi what it is, it is bound to actually perform so much better with only one prop per shaft and a two bladed one at that. In later years the actual ship was converted to slightly larger single props…which must tell us something? Ashley
        #17693
          Just out of interest, the green underwater section is far too low, in most pictures of the actual craft the "waterline" ie the top of the green was somewhere between the water and the deck…….why ??
          Just a bit more on your destroyer…what year are you pitching at ??  twin props per shaft would obviously look the business, but only on later TBD`s and POSSIBLY the first "river" class destroyers.  A cunning plan would be to have the mid shaft propeller just "windmilling" and have all the drive on the end prop…this gives the look, but not the hassle of driving two props .   Ashley
          #17698
          Steve Arendse
            @stevearendse23393
            yes ashley ,a sort of modern day- type of destroyer…mine is scratch built using basic materials and my own design….
            #1806
            Steve Arendse
              @stevearendse23393
