Time Bandit Build
Time Bandit Build
Home Forums Building Kits Time Bandit Build
  • #50146
    Robert Leckie
      @robertleckie12534
      Hello to all you UK members.
      You probably are all familuar with the TV series "Deadly Catch" and the boat named "Time Bandit". Well I have decided that I want to build an RC model of this boat.
      So to start, I'm searching for information data on the hull of this boat. Any contact info or data gratfully recieved. Photo's that I'v manage to get from the Internet are very limited and show the the bottom of the hull being flat?
      I will need to build a fiberglass hull, not easy but so be it.
      Thank you in advance,
      Regards,
      Bob Leckie
      Indonesia.
      #6154
      Robert Leckie
        @robertleckie12534
        #50174
        Amy jane September
          @amyjaneseptember49770
          Hi There Robert
          I did a quick search on Duck Duck Go, and found 30 odd photos (but sadly no lines plan) Yes, she is very flat bottomed with a rather scow like forward section. Being steel plate, she should build up easily in plywood, if that is an option for you, (In fact ply would be a better choice for that hull shape). All the best, and keep us posted!
          Amy jane
          #50181
          Robert Leckie
            @robertleckie12534
            Hello Amy,
            Thank you so much for your reply, most helpful indeed. I will take a look at Duck Duck Go site – there maybe some photos that I do no have. I amk also building the Eldergarth – slowly as I work in Africa and only get a chance to do something on my leave break.
            So, all the best,
            Regards,
              So you work in Africa but your home is in Indonesia, right? Wow!
