thin plywood
thin plywood
Home › Forums › All things floating › thin plywood
  • #20347
    Andy Hustler
      @andyhustler32076
      Gentlemen and others who dont fit in to that catogry !!!!!!!
      I am after a couple of sheets of 1mm plywood any suggestions of websites i can search ???
      Andy from Cardiff
      #3339
      Andy Hustler
        @andyhustler32076
        #20352
        Dr John Booth
          @drjohnbooth43899
          Andy
          Look for “liteply” and not plywood.
          You should find what you are looking for.
          John
          #20359
          Andy Hustler
            @andyhustler32076
            Thanks john,you know what i meant any way.Same horse diffrent jockey !!!
            #20362
            Scousegit
              @scousegit47585
              Andy,
              Most good timber merchants should stock ply of this thickness. It will probably be in sheets of 8’x4′ but if you are nice to them, they may cut it down to the size you want.
              Scouse.
              #20446
              Ernest Warwick
                @ernestwarwick40054
                Andy
                I,m assuming that you want Marine Plwood……If so, the man to speak to is Nick  Tonkin at Model Dockyard, he carries a good selection in Metric and Imperial sizes.
                Ernie Warwick
                Edited By Ernest Warwick on 25/04/2009 16:51:38
                Edited By Ernest Warwick on 25/04/2009 16:52:53
                #20447
                  I don’t think you will get marine plywood in that thickness. Robbins go down to 1.5mm thick in marine play (expensive!) and also waterproof birch ply. http://www.robbins.co.uk/
                  Andy Hustler
                    @andyhustler32076
                    Gentle men many thanks for all your replys it’s good to know that thereare folk out there willing to give help and advice freely.Tell you what lets form the next govt !!!!!
                    many thanks
                    Andy from Cardiff
                    #20470
                      Don’t get me started about our so called government and their cronies in all the political parties……bring out the trough and fill it from the gravy train.
                      Just how many ways are there to claim expenses for sitting on your ar-s and talking bollo-ks.
                      Ernest Warwick
                        @ernestwarwick40054
                        Hi Andy
                        Further to my recent reply to your “Thin Plywoodd” question………..Nick Tonkin at Model Dock Yard can supply  0.50mm, and 1.5mm Birch faced Marine Plywood in sheets of
                        3ft x 1ft…….if you have the sheet cut in half, it works out cheaper. Be aware that LITEPLY is mainly used by the Model Aircraft lads, and if you are using it on a working ship model it must be sealed 100% to avoid damp penetration………Good luck with your project, Ernie
