THAMES SAILING BARGE
Home Forums All things floating THAMES SAILING BARGE
  • #31827
    LARRY WHETTON
      @larrywhetton68737
      A VERY NICE BUILD, nice sail rig , have a KITTY half built but
      stuck how to rig it . yours looks the super …….LARRY…
      #3763
      LARRY WHETTON
        @larrywhetton68737
        #31849
          Larry…..How about this?……
          For the static rigging, just copy what you see, on the above photograph
          For the sail controls, I would suggest a sail arm winch with a strip of wood fastened to the servo arm.
          The wood strip will have several holes along it`s length.
          The servo will have an actuation angle of about 40 degrees…ie 20 degrees either way
          Simply, fasten cords to any convenient hole, take the cord up through the deck, using a chunky brass eyelet…then to the sail or sail boom
          For more fun. use several servos and control any number of sails individually
          Any problems….post a question
          LARRY WHETTON
            @larrywhetton68737
            HI BOB , thank you for reply, will try your rigs when HDML is finished ……LARRY….
