Hello Who Boot
The sprockets are supplied by Hobby's Ltd
But, as supplied, the hubs are not strong enough to use in conjunction with 6mm shafts
I made the hubs on a lathe and bolted them to the plastic sprockets
I used 6BA screws tapped into the hub flanges. The shafts have flats filed for the screws to act on.
These screws are not grub screws, but just normal cheese heads screws
If you require any further info, just ask
