Spray Strips
Spray Strips
Home › Forums › All things floating › Spray Strips
  • #15929
      Advice sought,
      My current build project is a scratch built replica of the Veron ‘Police Launch’. This is a hard chine hull design. I have built the hull and have planked this with vertical balsa sheets (as Glynn Guests ‘Higgins Hellcat’) instead of ply skins. As the hull is now nearing completion, I noticed the lack of spray strips from this hull’s design.
      How critical are these strips? should I fit them even though they are not shown on the plans, and if so what size material for a 26" long hull?
      A photograph of the original model can be seen in this months MB, Focus on scale item, page 34, photo 5. It looks from this photograph that this original model boat was not fitted with these strips.
      Thanks, Tony.
      #15930
        Hello Tony
        The answer to your question is fairly self evident as all you need to do is ask yourself if you want the model to be accurate (to the plan) and not have spray rails or do you wish the model to perform better in the water and so therefore fit the rails.
        Personally I would fit the rails as I prefer the better performance and it is also perfectly feasible that the river police improved the design by fitting the rails to later craft.
          Thanks Paul,
          I was enquiring at this stage, as a white water line crosses the strip. It would therefore be a neater job to fit the strips before painting. To have built the model, found performance in need of improvement and then retro fit the strips would obviously mark the hulls finish.
          Further thoughts are that I am not building an exhibition standard model, more a sport/fun launch.
          Tony.
          #15948
            Tony, fit the rails, there is no other choice. If you dont fit the rails initially you will forever wonder how much better it might with them on, and be forced to fit them later, and as you say, ruin your fabulous paint job . Ashley
            #3269
