Splicing a Battery Lead
Home › Forums › Beginners › Splicing a Battery Lead
  • #80201
    Peter Brown 17
      @peterbrown17
      I have a SLA battery as the power plant for my boat and it is connected (14 AWG wire) to the ESC and a Turnigy 7-channel receiver. All ok there. I want to power the navigation lights and a deck-mounted spotlight and have been told that 'splicing' into the battery lead between the battery and the ESC is the thing to do.
      The navigation lights and spotlight are resistor-fitted. How do you splice or take a spur off the battery leads to run these lights (and any other add-ons such as additional deck lights, sound modules, etc)
      I'm also wondering how the lights can be operated from the transmitter.
      Any steers on this would be really helpful.
      Thanking you,
      Peter
      #2813
      Peter Brown 17
        @peterbrown17
        #80203
          Peter
          Your best bet would be to use a power distribution board such as the ACTion P92 or P112. The battery is connected directly to the two input terminals and the board provides for a number of fused output terminals at the same voltage as the battery from which you can run auxilliary functions.
          To switch such functions from the transmitter you need an approriately-rated RC switch. This is connected to a spare receiver channel.
          You can find any number of circuits involving DBs and switches on this website https://action-electronics.co.uk/wd.html
          and ACTion units can be bought on-line here **LINK**
          Edited By Dave Milbourn on 05/12/2018 09:23:51
          #80204
          Peter Brown 17
            @peterbrown17
            Thank you Dave – I'll get one of those (and a spare)
            Peter
            #80205
              Peter
              There are a couple of articles here about RC switches – just scroll down to the title and click on it. **LINK**
              BTW if your speed controller has battery eliminator circuitry, or BEC, which means that the receiver works from the main battery and not a separate 4-cell pack then you shouldn't use the 5v red-and-black flylead on the P92. Just leave it unplugged.
