Speaker Mounting
Speaker Mounting
Home › Forums › All things floating › Speaker Mounting
  • #64067
    David Marks 2
      @davidmarks2
      I wish to fit a 50mm – 8 ohm Myler speaker into my current project. Any suggestions/recommendations regarding the correct mounting i.e. does it need a baffle board?
      Thanks in advance David Marks
      #4304
      David Marks 2
        @davidmarks2
        #64081
        Graeme Linskey
          @graemelinskey75588
          with a baffle board or a small wooden box will make a huge difference as the speaker fires it gives waves from the front and the back you don't want the reverse sound bouncing back to the front destroys the sound
          #64082
            All speakers need a baffle board if you want them to be heard. The longer the air path from back to front, the better. If the back of the speaker can be enclosed in a container that doesn't let sound through, that is good. The bigger that space, the better. It also needs a clear air path in front, to let the sound out of the boat.
            #64114
            David Marks 2
              @davidmarks2
              Many thanks. Mounting made and incorporated into wheel-house floor.
              #64115
              CookieOld
                @cookieold
                Hi David , I have mounted my speaker on a board flush with the top of the hull and used the hull as a BOOM box as they say and it sounds great .
                Dave wink
