SLOW-MO-SHUN
SLOW-MO-SHUN
Home › Forums › All things floating › SLOW-MO-SHUN
  • #29708
    LARRY WHETTON
      @larrywhetton68737
      hi PIERRE ,nice model what running format are you using?…
               and what scale is it?………LARRY..
      Edited By LARRY WHETTON boatman73 on 02/02/2011 16:42:26
      #3697
      LARRY WHETTON
        @larrywhetton68737
        #29715
        Pierre
          @pierre
          Hi Larry
          Wow, that photo is a blast from the past – I haven’t run that model for about two years!
          The plan was found from an old site dating from the early 50s of Popular Mechanics.
          It was a tethered runner with an ic engine. The plan was A4 format which I enlarged. Offhand I cant remember the scale but the boat’s length is about 75cm – I relied quite heavily on an article in MB about the Billings model.
          I’ve got a Speed 700 motor in it running on two 9.6V NiMh packs. The prop is a Graupner plastic 2 blade 40mm.
          The boat goes like stink with a huge rooster tail – it’s great going in a straight line, turns are a bit more of a problem!
          I’ts been sitting on the shelf waiting for me to summon up the courage to go brushless- also I’ve been busy with various other builds .
          As you gather the paint scheme is nowhere original!!
          Pierre
