Forums
Help
Register
Log in
Home › Forums › R/C & Accessories › Servo Arms
I just wanted to know if Futaba Servo Arms would fit Acoms servos. Regards Colin D
Probably not. The size and number of splines is one of the areas where manufacrurers like to demostrate individualism.
Thank you for that information Malcolm I was hoping that the number of splines would be the same. Regards Colin Duerden
Sometimes you get lucky – if the arm drops on reasonably firmly with no sign of play when waggled (tech term) then it matches and no problem. If it needs forcing, they don't match. If it just drops on and falls off then, again, they dont match.
Thanks again Malcolm Read and Understood as they say. Regards Colin
Philip Oxley
Boiler Bri
Dodgy Geezer 1
