Robbe Le Courageux by Luke
Home › Forums › R/C & Accessories › Robbe Le Courageux by Luke
  • #5198
    lukey81
      @lukey81
      R/C gear compatibility
      #37894
      lukey81
        @lukey81
        Hello Everyone
        I was wondering if anyboby would mind helping me in answering these quick questions regarding the Robbe Le Courageux, I have recently brought the boat kit & am buying the power set and fittings set shortly…now i built Billing Boats Andrea gail B526 and used a ready made R/C package and a Mtronicks 15amp speed controller and it worked just fine and was heading along the same lines for the Robbe Le Courage but wanted to see if anyone has built one before and what sort of gear they used? below is a list of gear i hope to fit but wasnt sure if it will work? if anyone would mind shedding some light on this topic it would be much apprieciated! thank you very much guys…
        Futaba Attack 27mhz R/C package-Transmitter, R122JE/R152 Reciever & 2 x S3003 standard servo's
        I wasn't sure if the Mtroniks Viper Marine 15 amp speed controller work with Futaba gear mentioned above? and also will the speed contoller be compatible with the Le Courageux power set motor which is a Robbe Power 755/40-with current Amps at max.efficiency 4.50 A with max power of 8.00 A 12-18 volts?
        any help at all would really help! Thanks again
        Kind Regards
        Luke
