Request for plans.
Request for plans.
Home › Forums › All things floating › Request for plans.
  • #3810
    Dry Dock.
      @drydock
      #33571
      Dry Dock.
        @drydock
        Hi everyone, I've put a request in the Scratch Build section for a set of plans for a beam trawler published in Model Boats, November 2000 issue. If anyone can help I would be most greatful. Hope you dont mind me repeating it in this topic.
        Regards, Bob Powis.
        #33827
        Andy Hustler
          @andyhustler32076
          Hi bob it's a bit late a night now but i will have a dig through my mags later on . If i have it it's yours for the price of a donation to rnli,ssafas, british legion or help for heros . Cant promise but will look for you .
          Best wishes
          Andy
          #33835
          Andy Hustler
            @andyhustler32076
            Hi bob , I have had a look through my files and found the Magazine and the free plan to go with it . Let me know your adress and i will send it on to you within 24hrs of geting your adress , depending on the post !!!!
            #33882
            Andy Hustler
              @andyhustler32076
              Hi bob i just got your message and will try and post in morning , failing that after the easter holidays . Send me a picture after you have made it .
              Best wishes and happy boating
              Andy
              #33922
              Dry Dock.
                @drydock
                Cheers Andy, this is going to be a first for me, I've been told its plank on frame, I've bought a really good fret/scroll saw (Hegner, spending some of my retirement money) so lets hope I can cut the bulkheads out correctly, and then get the planking right, I'm going to build it in a jig to stop any warping. I will of course post some pics on the site as it progesses.
                Many thanks for your help, Bob.
                #33954
                Andy Hustler
                  @andyhustler32076
                  Bob sorry for the delay in getting your mag and plan out to you and i will post on tuesday . I have not been able to do before due to lack of funds . .
                  #33983
                  Dry Dock.
                    @drydock
                    Andy, when you send the plans please include your address so I can re-enburse you for the items plus the postage.
                    Regards, Bob.
                    #33991
                    Andy Hustler
                      @andyhustler32076
                      Bob all i request is you throw a few coins in the RNLI, SSAFA ,BRITISH LEGION or HELP FOR HEROS .You are more than welcome to these items as i would rather someone put them to good use than sat here gathering dust ..
                      #34110
                      Dry Dock.
                        @drydock
                        Hi Andy, THe mag and plans arrived today, many thanks, they are exactly what I needed, I'll keep you updated with the building. Like yourself I'm also building Italeri's E Boat, I spent quite a bit of money on it, ordering the scale props from Prop Shop, along with the shafts, I've installed them exactly to scale and without any deviation from the angles they are set inside the hull, I'll post some closeup photo's of the work sofar. The shafts fit very low inside the hull and I'm having a problem getting couplings on the two outer shafts, I dont know why I bothered with the two outers, I might just leave them for scale looks, and only connect up the centre shaft to a motor as this model runs very well on just the one prop. I'm also making the large rear end support and bearing for the centre prop and shaft in brass instead of the plastic one you'll see in the photo's. Good luck with your build, and I'll let you know how my one comes along.
                        Regards, Bob.
                        #34112
                        Dry Dock.
                          @drydock
                          Andy, I've added the photo's of the Shaft and Prop installation on my Schnellboot.
                          Regards, Bob.
