Radio interference
Radio interference
Home › Forums › R/C & Accessories › Radio interference
  • #10691
    John Billinge 1
      @johnbillinge1
      Hello,
      I use a Digifleet FPS-24B speed controller, fitted with the supression kit,  with a Marlin type electric motor in a Fairy Swordsman, an old aerokits model. What ever I do, I cannot stop the motor starting to run when I activate the rudder.  Any ideas about how to cure this would be appreciated.
      Regards, John.
      #13042
      Jake Knight
        @jakeknight71345
        ok ive had the same problems in the past
        what i was told to keep the reciver as far away from the speed controller
        and keep the speed controller as far away from the motor and
        also keep the arial as far away from every thing (staright up works for me)
        #13044
        John Billinge 1
          @johnbillinge1
          Hello Jake,
           I agree with what you say but the degree of separation is dependant on the size of the model.  However,  matters are  much improved now that I have switched to a Futaba computer controled 2.4Ghz transmitter and receiver.
           Regards,
           John.
          #4923
          John Billinge 1
            @johnbillinge1
            #30305
            Jeremy
              @jeremy15845
              Does the switch to 2.4 Ghz completely eliminate all interference problems or should one continue to follow the advice outlined by Dave Brumstead in this Model Boats article (winter 2010 issue) to keep motor supply voltage wiring away from receiver output wiring and the aerial away from proximity to the motor?
              Jeremy
