Pulling out pins?
Pulling out pins?
Home › Forums › Beginners › Pulling out pins?
  • #13527
    Greg Smith
      @gregsmith33444
      OKwhat’s the tip? I have bought an Amati pin pusher and starting to put on my first planking of plank on bulkhead. I am doing the Caldercraft HMS Badger and it says pins the plank as it dries. (I don’t want to use cyno only Aliphatic)
      Do I go out and buy myself some map pins as they seem more sensible, or use brass pins?
      Anyway, my main question is how do you remove a flush fitting pins if you make a cockup. Is there a tool? (other than yourself of course for making the error in the first place)
      #13529
        Hi Greg
        There is no tool (except yourself and believe me we have all done this) so use pins with heads or collars or as you say map pins.
        Greg Smith
          @gregsmith33444
          P on B
