props
props
Home › Forums › All things floating › props
  • #4143
    charlie f
      @charlief
      #51646
      charlie f
        @charlief
        I am refitting a 36" raf tender sort of Vosper style. I would like to use a 540
        motor with 6 cell Nimh batteries. what size prop should I use
        #51654
          You'll be disappointed with the performance if you use only a 540 on 7.2v, irrespective of the prop size. If you don't want to go down the brushless motor route then I would recommend a Speed 700 BB12v motor, running on 10 Sub-C NiMH cells or a 3S LiPO, with something like a 40mm 3-blade prop. **LINK**
