Pop Pop engines
Pop Pop engines
Home › Forums › All things floating › Pop Pop engines
  • #3627
    StuartM
      @stuartm
      Viable power plant
      #28258
      StuartM
        @stuartm
        Dare I mention them on here  or shall I lash myself to the ships wheel ready for the flogging.
        Just wondering whether or not anyone has managed to power a model with one (or two) rather than those little tin pressings
        Ta
        StuartM
        #28259
          Stuart.
          The subject is fairly well documented, see here: http://www.nmia.com/~vrbass/pop-pop/
          I don’t know if any of our members have built one though.
            Hello Stuart and Colin
            It was our Autumn regatta yesterday at Etherow
            This year`s Commodore`s Challenge was to construct a powered boat, which could steer a figure of eight course….without the use of an electric power source, but RC controlled
            Three boats entered……one clockwork……one lacky band…….and one, a home made Pop Pop drive and it worked well……..It ran for quite a while, compared to the other two motive powers
              Nothing wrong with pop-pop`s.
              After all,how many craft do you see on the water powered by a jet engine??
              StuartM
                @stuartm
                Thanks all,
                I’ve always been intigued by them.   Years ago I  built 2 small coiled tube ones powering 6 -8 inch craft, (slab of wood with a pointy bit)
                 I was wondering whether anyone had scaled  them up and run one  RC controlled in a large hull up to 3′ ish.
                I might have a bash and see if I can power my launch with one. If it fails I’ll plug the holes and install conventional electric.
                 It will be an interseting winter project if nothing else.
                #28271
                  Interesting project, scaling up a pop pop.
                  Hobbies sell pop  pops that look like upright boilers and they say 2 of them will power a craft of the size contemplated.
                  I think you would need a lot of extra heat to scale up one of these engines and then materials would become an issue.  Perhaps you could make a multiple chamber/coil unit , thus having in effect 3 “engines” as one unit to give more power without making the actual units themselves much bigger?
                  StuartM
                    @stuartm
                    I’ve seen that one in Hobbies.
                     I might try multiple coil units encased in a single large diameter tube, with a gas burner as a controlable heat source and play around with tube diameters.
                    Watch this space .
                    Stuart M
