Planking
Planking
Home › Forums › Building Kits › Planking
  • #19618
    Richard Pegden
      @richardpegden16734
      I am just about to start building the Mantua Amerigo Vespucci. In the instructions on planking it offers the option of using modelspan paper as the 2nd skin. Has anybody had experience in using this medium and what were the problems and results.
      #5981
      Richard Pegden
        @richardpegden16734
        #49043
        Charles Hopkins
          @charleshopkins93180
          I'm slightly ahead in that I have finished the first planking on the Amerigo Vespucci and now I have the same question about using Modelspan paper. I have raised this question with Mantua's help email address but so far no reply. I'm concerned about getting creases in the paper as it fits around the bow and stern areas. Will the paper shrink enough with the application of dope so that it takes the curves without creasing or do I need to cut it first. Any advise will be gratefully received.
          #49045
          Martin Field 1
            @martinfield1
            If you've made a good job of the planking, all you should need is a coating of epoxy resin, inside and out. Use some very lightweight cloth if you must, but I've never seen any point in it, and who wants to sand glass?
            If you're going to paint it, give the epoxy a good rub down with wet'n'dry, then rub it well with a lint free cloth soaked in cellulose thinners to rid the epoxy of any of its free styrenes, which leach out of the surface to give a slightly waxy feel.
            If you're varnishing do the above and then use a good spar varnish like Epiphanes. It works especially well over epoxy and is what Rivas use and Peter Freebody when restoring Rivas. There IS no finer finish
            If you've made a bit of a planking cock up, then you'll probably need the glass cloth and epoxy coating to fair the hull out<G> That's OK, we've all been there, done that when time was pressing. You don't want to see my Zulu hull, before I got a coat of thickened resin on it (still no cloth though), but when I'd finished with abrasive and spray gun there sat a model that won an award in a New York gallery!
            Push on!
            Martin
            #49063
            Charles Hopkins
              Thanks Martin great advice.
              #49103
              Martin Field 1
                @martinfield1
                Here's a VERY carefully planked Miss America X and a less carefully (but you'd never know it) Zulu
                Now in Arty's Restaurant, Fairfax, Virginia.
                The very obvious reef lines were, for reasons unknown, the whole point of the model at the Art Gallery. Made for a Scottish doctor.
                My wife made a superb job of dying and making the sails, bolt ropes, cringles and all. She used to make naughty knickers for a living!
                Cheers,
                Martin
                Edited By Martin Field 1 on 24/05/2014 14:43:45
