plank bending
plank bending
Home › Forums › Beginners › plank bending
  • #17796
    Stephen pytel
      @stephenpytel58163
      a friend of mine was building a fullsize boat in his garage , I was very impressed with the steamer which he had made for that project .
      I had an idea  and this works just as well and a very safe way of bending planks
      1. boil some water in  a kettle
      2. either use a kitchen bowl or breakfast bowl . or a tray with no holes
      3. a clean chux waper [ just a cleaning clothis just as good
      by putting the boiling water in the bowl with plank wrapped in this cloth note [  if using the bowl I would do one  plank] and then push it all the way through fully emursed in the boiling water .
      what this does subject the [plank to boiling water [ same as steaming ]
      I had another problem, I had glued 4 planks together and needed to move them down
      what I did was carefully  wrap the same cloth as above , around the four glued and then the steam from the boiling water released and also allowed me to bend these planks without destroying the glue
      #1812
      Stephen pytel
        @stephenpytel58163
