Planet T5 throttle control
Home Forums R/C & Accessories Planet T5 throttle control
  • #32680
    Jeremy
      @jeremy15845
      I’ve used the T5 for six months now with reversable speed controllers and it works fine Happy.
      However, now I have a problem – I want to use the T5 with an Overlander
      XP speed contoller on an Orlyonok A90 Ekranoplan powered by one tail
      mounted propellor. Problem is that the speed controller will only start
      when the centre sprung throttle stick is pulled fully down (reverse on
      most of my boats). Releasing it to the centre position then leaves the
      prop going at half speed which is not ideal from a safety point of view
      Sad.
      Overlander tell me that I cannot force the speed controller to
      recognise or accept the mid position as zero throttle. Any suggestions
      as to how to solve this problem would be appreciated. However, I still
      want to be able to use the T5 as it is for my other boats.
      Jeremy
      #5149
      Jeremy
        @jeremy15845
        Centre weighting with non reversible speed controller
        #32688
          Why not take the centring spring off the other Tx stick and use that channel for the throttle on your non-reversing ESC?
          Jeremy
            @jeremy15845
            Great idea – thanks. I will do just that.
            Jeremy
