Paint Advice
Paint Advice
Home › Forums › Beginners › Paint Advice
  • #66498
    Dave Kershaw
      @davekershaw17501
      I've previously built wooden boats and used Humbrol enamel, but at the moment I'm renovating a Graupner RTR PT 109, im not 100% sure of the Hull material, looks like some mixture of Plastics, glass fibre, So Im wondering if Enamel will be ok. If not Please could you help:
      Recommend Paint Type, best place to get it from etc ( it will be on the Water at some point )
      Many Thanks
      Dave Kershaw
        @davekershaw17501
        #66499
          Bearing in mind that any surface, whatever it is made of, needs proper preparation before paint is applied, Humbrol enamel has worked on all of the models that I have ever made that needed paint (starting with the then newly issued Airfix Gladiator).
          I like to shoot the plastic items with a layer of Halfords grey primer as an undercoat. So far it has failed to melt any of my models and provides a consistent opaque base layer for the paint pigment to sit on.
