Over specifying ESC amp rating
Home › Forums › All things floating › Over specifying ESC amp rating
  • #4510
    Terry Plumridge
      @terryplumridge66794
      #77914
      Terry Plumridge
        Does it hurt to go for a higher than needed rated esc?
        #77915
          Only in your wallet….
          Terry Plumridge
            Thank you Mr. Milbourn.
            #77920
              I hope you don't think I was being flippant at your expense, Terry. The full answer is that while it's perfectly OK to use an ESC which will carry more current than the motor will draw it's never a good idea to use one which won't.
              Terry Plumridge
                No flippancy detected in your reply, it was short, to the point, and not without a touch of humour.
                Cheers, Terry.
                #77932
                  ON the other hand….I have found that high current ESc`s that are operating at currents well below their max sometimes do not have such great low speed control, or it may be just the controller I had?
                  Kev.W
                    @kev-w
                    But whatever you do, don't try running a 100amp motor on a Chinese 320amp ESC. wink
                    #77938
                      It's the latter, probably one of the type Kip mentions. In my experience if you take the stated current-carrying capacity of one of these products of the PROC and divide it by 20 then you're somewhere near reality.
                        Generally, what will control a large motor will control a little one just as well. A badly designed ESC, whatever its current rating, or claimed current rating, might not start to give an output until you are at 1/4 throttle. The usual back story was that "it makes sure that the motor starts".
                        For fine control, the better option was a gradual increase in power offered before the motor actually started to turn with very little dead band. In the elder days, this caused the motor to hum or growl, in later ESCs, the motor whistles.
