David. The crystal thing is simple. Please do not take offence at this easy explanation.
The set operates at 40Mhz. In order to focus the Hertz`s into channels (within the broad 40Hz spectrum), tuning crystals are used; they come in various frequencies (giving the channels) as marked on the things, You have to have one in the Tx and one in the Rx, obviously they need to match..ie be the same frequency) in order that the tx and rx operate as one. I hope thats explained it. Sometimes we take these things for granted.
For instance 40.685 is one channel, 40.695 is another and so on.
If you have two boats, you only need the pair of crystals, the tx marked one stays in the Transmitter and the Rx one can be moved to the reciever units in either boat….OR you get two pairs (of the same frequency)…and use one each Rx crystal in each boat (to save swapping about) and the one Tx crystal in the Tx unit.
Assuming yours is an FM set then the crystals spotted will be ok BUT the Tx one is in a little holder and the holder needs to fit your handset of you is in trouble. I have two makes of 27M sets and they had holders (long gone now) but the crystals simply plug straight in the little hole.
The 2.4Ghz sets do away with the crystals by using different technology, and all you need then is a transmitter and the corresponding manufacturers reciever, the pair are "bonded" electronically. This is what makes it easy, there is no need to have loads of crystals, any new recievers you buy are simply bonded to your personal transmitter and thats that.
Please be aware the only correct use for stockings is to cover boat hulls in prior to applying fibreglass/epoxy resin.. Wellies are the recommended footwear at the pond, at least, our pond..but customs vary, and we are down south…..
