need help with motor size & prop
Home › Forums › All things floating › need help with motor size & prop
  • #4342
    DOUGLAS BUSHELL
      @douglasbushell19364
      I have a small venice type motor boat
      #66617
      DOUGLAS BUSHELL
        Hi I have been given a used motor boat approx. 20" x 6.5" by only 2.5" from deck to the keel. so not much space. I will need a very small powerful motor.
        Any one out there that can suggest what motor & prop I can use , it would be a great help.
        Many thanks for looking at my post.
        Doug.
        #66620
          A photograph or two would be greatly appreciated, Doug.
          DOUGLAS BUSHELL
            Hi Dave thanks for your reply, I will try to add photos. Not sure how to do this.
            Doug.
            #66626
              Check 'Frequently Asked Questions' on RH column of this page. Files must be JPG and I'd suggest 300-400Kb.
              For a brushed motor setup I would suggest the one I used in my little 20" Swordsman i.e. 7.2v Speed 400 **LINK**, MTroniks Micro 10A ESC **LINK**, 7,2v NiMH AA pack **LINK**, 25mm 3-blade prop. If the NiMH pack is too large then you'll need to go to a LiPo 2S.
              Edited By Dave Milbourn on 19/07/2016 09:35:31
