motor voltage
motor voltage
Home › Forums › All things floating › motor voltage
  • #54279
    sammyk
      @sammyk
      Hi, i need some help i have a small electric motor about 380 size with no name or numbers on it running on 7.2 volts.can i run it on 9.6 volts,its in an old model from about 1978 . thanks sammyk
      #4175
      sammyk
        @sammyk
        #54280
          Sammy
          With that level of information I'm afraid there's no way anyone can say. You'll just have to try it and see. If you burn it out then a new one is only about a fiver – plus you'll then know what the rated voltage is!
            As above, but if it loaded lightly rather than maxed out it may well run ok..it is the current draw that is likely to burn it up, rather than simply a lot of volts. Applying more voltage will of course ramp up the amps and so…whooof!!!
              Sammy
              Like you I use kit from all sorts of places and un-branded motors can be a good source of cheap and cheerful equipment however there are downsides like not knowing the amp or voltage limits.
              It might be a good idea to invest in a multi-meter so that you can test each item individually then you will be able to assess your equipment and know the upper limits, a multi meter is a great piece of equipment and very easy to operate.
              I hope this helps
                Un-branded motors can also be a source of endless exasperation, expense, embarrassment and stress unless you really know what you're doing with them.
                I'm not having a pop at anyone but it baffles me how many modellers will happily fork out hundreds of pounds for a kit, fittings, glues, paints and a radio and then sling into it a scrappy unmarked motor which they bought for a quid somewhere. What's the current on load? What voltage rating does it have? What's the stall current? How many poles are there? How many winds on the armature? The answer to all is usually "I don't know".
                Sorry, guys – I've had to sort out so many problems with the electronic consequences of this short-sighted practice that I always recommend buying a known, branded motor with some basic performance details (either on it or on a website) from a reliable supplier. Save a tenner on the motor and blow up a thirty quid speed controller? I've lost count of the number of times I've seen it. Sammy – please save it for ballast and buy an MFA 380 or 385 – you'll get change from a fiver for either of them.
                Kev.W
                  @kev-w
                  Posted by Paul T on 12/12/2014 13:54:56: a multi meter is a great piece of equipment and very easy to operate.
                  I hope this helps
                  All well & good Paul, but you are presuming that, once a person turns on the meter on the correct mode, they will know what the meter is telling them. wink
                  It's my experience, that most people can't tell the difference between an ohm & a kelvin, likewise, you could own the best toolkit in the world, but still not know the difference between a small end bush & a crank thrust bearing smiley
                  #54304
                    Dave (bless him) wink is absolutely correct in what he says about not skimping on a motor when buying an expensive kit but those of us who live on the other side of the lines cant afford a posh kit and usually end up nailing planks and milk cartons together to make a model and will fit any old motor that we can scavenge.
                    Sometimes they work and sometimes they don't…………which is all part of the fun.
                    Kip
                    As you very rightly say its no good buying a fancy meter if you are not prepared to learn how it works but when you do know how to twiddle the knobs it can save a few bob in electronic mishaps.
                    whats a crank thrust bearing? thinking
                    #54318
                    sammyk
                      @sammyk
                      Hi lads thanks for your input, the motors in question are in a model submarine with 30mm props and they each draw 3amps at full power in the water so expect it to be lower than that when it is not tied up to the shore.i knew it was a bit of a long shot with so little info on the motors i may just have to give it a go but will have to wait till spring time for deeper water.regards sammyk ps i use a multi meter allmost every day at work
                      #54324
                        Dear Kevin
                        Please don't think that using unknown motors or equipment is as straightforward and simple as I might make it seem. Before using unknown motors I always thoroughly bench test them first to establish optimum voltage and amp draw so please don't go putting any old motor into your pride and joy without checking it out first.
                        I might pull his leg but Dave Milbourn is undoubtedly one of this countries leading experts on model electronics and his sage advice about buying decent equipment is well founded.
