More realistic sailing
Home Forums Scratch build More realistic sailing
  • #44010
      I was watching the latest club video this morning…..Courtesy of our intrepid video expert…..Duckie
      It showed the members sailing their models etc…..One model was a lovely Tug boat towing two very nice barges…..But the setup didn`t look right
      Why was that, Bob?
      For a start the tow ropes were too short, but the real problem, was that the barges were as light as a feather!
      They would have looked more interesting, had they been heavily loaded to the gunnels and generating prop wash and bow waves from the barges
      I then thought about model boats in general. They seem to lack the water disturbance of the real thing
      Then an idea came to me!…….We spend hours making the hull super smooth etc, but for added realism……Why not add baffles under the hull to cause excessive drag and make the motors earn their living?
      I think it may be worth a try?
      When my Great Eastern was laying cable at New Brighton a few years ago, it had to work really hard, so the prop and paddles created excessive foam, which looked very impressive?
      Cable taught
      At the time, I didn`t realise what was causing it, but it must have been the paddles and prop, simply labouring?
      Food for thought?
          Or you could inject a bit of washing up liquid out of the hull at strategic points…
          Bob is quite right though, model boats look best when they are struggling a bit.
            Models generally lack the mass to achieve a good look on the water. i deliberately made my NELSON too deep so i could fit loads of extra weight in (for its size) to give it a bit of gravitas. Similarly as Bob says, the GE is VERy heavy and so the paddles starin a bit more. How about feeding compressed air through micro-holes under the hull to get a bit of foam going?.Washing up liquid..Colin, you card you. Ash
            #44044
            Dave_P
              @dave_p
              Sounds like we have found the chap who keeps dosing the local fountain with bubble enhancing material. smile p
              #44045
                LOL Dave
                It would have to be a big fountain, for GE to fizz up the water……..It`s 7`0" long
                I think the real culprit has already given the game away, with his washing up liquid!
                Dave_P
                  @dave_p
                  Washing up liquid was what I was referring to Bob.
                  I regularly drive through Hastings along the sea front and at one time it seemed at least once a month masses of foam would being emitted from the fountain.
                  #44058
                  Telstar
                    @telstar
                    Bob I recall ( I think ) some of the older modellers with steam driven Tugs adding short pins like bristles on the waterline at the bow to give a more realistic 'dogs bone' bow wave.
                    Tom
                    #44060
                      It was just a hypothetical postulation – honest!
                      Ian Gardner
                        @iangardner62867
                        I agree with Ashley- weight is what you want. My Underhill police launch weighs 25lb and doesn't half kick up a wave when travelling at full speed. No froth though!At Crealy 6.10.11
                        Edited By Ian Gardner on 28/09/2013 19:41:47
                        #44079
                          Hello Ian
                          Just a thought……You could try a finer pitched prop?
                          Or even an old plastic prod with a few holes drilled in the blade?
                          FLAT OUT
                          Here's a real froth maker!……If nothing else!
                          Ian Gardner
                            @iangardner62867
                            Hi Bob,
                            I'm pretty happy with the performance of my Dunlin (the above police launch). It's just dragging it to the water which is a pain- literally. It has a 2'' prop driven by a MFA 500 witha 6:1 reduction- 12v 7ah battery which I charge about once a year as a token gesture.
                            It seems counter- intuitive to drill holes in props- I wonder what would happen, and if anybody has ever tried it.
                            Incidentally, I love heavy models where you can actually hear the sound of the bow wave.
                            The hydroplane is certainly kicking up a fuss!
                            You couldn't resist the veneered deck then? Don't blame you, it will look very fine.
