Modify servo
Modify servo
Home › Forums › R/C & Accessories › Modify servo
  • #51467
    melvin hall
      @melvinhall89458
      I am thinking of using a servo to elevate gun barrels on a model. I was wondering if its possible to modify a servo so when its moved, it stays where it is and doesn't go back to the middle position?
      #5321
      melvin hall
        @melvinhall89458
        Looking to modify a servo for model ship function
        #51468
          Sounds like you might need one of these **LINK**
          A servo will always follow the movement of the Tx stick unless you put a device like this in between the servo and the receiver to alter that.
            A cheap alternative is to fix the stick so it stays put when you let go or remove the servo electronics and use a small ESC, effectively turning the servo into a motor and gearbox.
            #51473
            melvin hall
              @melvinhall89458
              Ok will try that, thanks for the help!
              #51789
              Jim Pinner
                @jimpinner
                Hi all I am a new member but have subscribed to Model Boats for years.
                I am about to start a 1/16th Severn Class lifeboat and want to have working wipers. I know this will be servo controlled but how does the servo operate on a continual basis when switched on the Tx?
                Any advise would be appreciated
                Jim
                #51791
                lnvisibleman
                  @lnvisibleman
                  Jim
                  I would have thought that it may be better to get a small very slow geared motor     http://www.ebay.co.uk/itm/MICRO-GEARED-ELECTRIC-MOTOR-120-rpm-3-6v-FOR-RADAR-CRANE-ACCESSORY-DRIVE-/261540850532?pt=UK_ToysGames_RadioControlled_JN&hash=item3ce50cab64              and make up the gear to change rotary to oscillating movement as in a real wiper motor. That can then operate from a simple switch.
                  Mike ( Think loco wheels, only in reverse )
                  Edited By lnvisibleman on 01/09/2014 22:46:38
                  #51792
                  Jim Pinner
                    @jimpinner
                    Hi Mike Doh why didn't i think of that such a simple solution to what appeared to be a difficult problem.
                    Many thanks
                    Jim
                    #51933
                    melvin hall
                      @melvinhall89458
                      Hi,
                      Thanks for the suggestions.
                      I bought a servo control unit, and it will give the correct slow control for gun barrel elevation.
                      Is it possible to use the same method to rotate a turret? Is is possible to modify a servo so it turns farther than just 45 degrees either way?
                      #51938
                        Yes the servo can be made to travel further http://www.modelradioworkshop.co.uk/products/turret-servo-controller
