MFA Tracker
MFA Tracker
Home › Forums › All things floating › MFA Tracker
  • #26287
    Ian Gardner
      @iangardner62867
      I was looking on Ebay and came across a link to this video. I was very impressed with the performance of this boat.
      Hope the link works but if not search Tracker 47.
      #3547
      Ian Gardner
        @iangardner62867
        I thought this was really good!
        #26311
          Very nice model, good performance, very adequate without being ridiculous.
          Bit noisy perhaps?  but who cares. i could have fun with that, no problems.
          Good value I think, those MFA hulls. A reasonable size the Tracker , able to accommodate all sorts of motors and a decent size battery. Performance of that specimen I would say on par or even a bit faster than my MFA Seahawk, which has a bog standard 850 motor and 12v 7Ahr gel battery, and is of slightly smaller dimensions and more than fast enough on our pond. Takes the rough water easily when others are afraid to venture, which is what i like.
          Ian Gardner
            @iangardner62867
            Funny, I sort of had you in mind when I posted this Ashley as I know you have a Fantome. Must say  I am quite tempted by the Tracker now that I have seen what it can do but I expect it will pass!
            #26314
              Thinking out aloud……..
              If you knew somebody who had an MMB900 motor and a pair of 12volts bat stix and an assortment of big props…..
              ………………Which of these MFA hulls, be most suitabell?
              You never know!…………….Bob
              PS……………. Thanks Ian, for the video
              #26317
              Ian Gardner
                @iangardner62867
                Hi Bob,
                The short answer is I don’t know, but judging by the video of a Perkasa I have seen with a MMB900 on 18 or 24 volts I would think  any of the big ‘uns would go well- I couldn’t presume to advise you but I bet someone will be able to. That Tracker was described as weighing about 20lb I think, which is hefty, but did have two 12v 3ah lead acid batteries.
                I am building a Lesro Rapier with two 700 motors on 12v each and I think that will fly but I’m interested in all this as my next boat will probably be a Sea Queen- I have the kit sitting on my workshop shelf and I am thinking of twin motors, maybe 900s or may venture into the dark realms of brushless- will need some advice on all of it when the time comes!
                I sense that you are contemplating a new purchase -I await with interest.
                By the way, my video link didn’t work- I simply copied and pasted the You Tube link. What should I have done-anyone?
                #26318
                  Thank you, Ian
                  You need a gap between your words and the pasting……viz
                  That`s how you do it!
                  It`s my birthday this month and I just thought something that would take my latest motor stuff might be a good idea
                  Ian Gardner
                    @iangardner62867
                    Well happy birthday Bob and I hope you get something good. Thanks for the link advice. This is the Perkasa video I was talking about- I suspect it is well known but it gives me a chance to try posting a link
                    #26321
                    Ian Gardner
                      @iangardner62867
                      Nah, still didn’t work-aaaagh!
                      #26322
                        Hello Ian
                        You must have a space before you paste…….use the space bar!
                        Now, try again, there`s a good chap!
                          Bob, anything other than the tiny one, or the Fantome which really needs to be 2 props unless gas powered, or from a more practical point of view the F is a bit more volumetric to store than the others, shed-wise. However if your turbo 900 is as powerful as we are led to believe, it may be sufficient on its own?
                          Ive said it before, but I rather like the low revving motors on the old F, its rather refreshing after lots of high speed screaming (ha..on most of me other craft..I take no prisoners to scale speed)
                            Thanks Ashley
                            I was thinking that if Slo Mo doesn`t improve itself……………..I could use the gear in something else…………………..something more sensible!
                            The gear train mod may be the last straw!
                              I cant see smaller higher speed props helping slo-mo personally…they may well work once its going fast but its the getting there thats the problem, …I just cant see smaller props having the bite !!
                              Anyway, you have not finished with the mods yet.
                              Sponson shape;
                              removal of filler between sponsons, and/or LOWERING the filler just to the level of the first small step;
                              different props;
                              removal of fans & watercooling;
                              full width transom flap;
                              splitter plate between props;
                              gearing to increase prop size;
                              gearing to decrease prop size!
                              temporary fillers to alter stern profile;
                              temp filler to alter bottom profile completely (from initial small step to a flat rear end)
                              running with only one battery  ;
                              Thease are all things I would try before selling up.
                              gas engine!!
                                Thank you, Ashley………..I`ll give your list some thought!
                                I think you`ve posted in the wrong thread?
                                Sorry Ian, for digressing
                                Ian Gardner
                                  @iangardner62867
                                  Not at all Bob! There’s only so much one can say about a video.
                                  I find it all interesting and I can’t bear  to make a public fool of myself again trying  to post a video link!
                                  If you do decide to go down this route, there is a post on another well known forum where a gentleman describes a good performance with an MFA Spearfish and a 900 motor on 15 cells- just food for thought. I should think it practically took off.
                                  I must say I’m tempted by these MFA boats but I must stay strong!
                                  Godd luck with Slo-Mo.
