M4 thread
M4 thread
Home › Forums › Scratch build › M4 thread
  • #41149
    Ian Gardner
      @iangardner62867
      Hi,
      I want to tap an M4 thread in the hub of a pulley I shall be turning, to fit the thread of an existing shaft. Can anybody confirm that it is 4 x 0.7 that is commonly used for prop shafts ie M4 course, rather than the fine thread, before I go spending money on the wrong size tap? I read that the course thread is the default (Wikipedia!).
      Thanks….Ian
      #6877
      Ian Gardner
        @iangardner62867
        Which thread- fine or course?
        #41150
          Why not give MMB a ring? They make shafts, after all.
            Hello Ian
            I've always used….M4 x 0.7 pitch
            Tap drill….0.128"…..or 3.3mm………No30 drill
            Clearance drill…….4.5 mm
            Don't know the fine pitch info
            You could measure your existing screw thread…..For peace of mind?
            Ian Gardner
              @iangardner62867
              Thanks both- I did consider ringing either Model Boat Bits, where I have bought shafts, or MMB but it seems just a bit cheeky- and this is presumably the sort of thing these forums are for!
              I'm pretty sure it is M4 x 0.7 but just need confirmation before flashing the cash.
              Bob- do you mean just measuring with a ruler or vernier, ie 0.7 between peaks and would that be accurate enough? I will try it though, with my newly bought digital vernier, just to see- thanks. As you can tell, not that experienced with things engineering but want to give this a go.
              #41165
                Hope this helps,
                Tony.
                #41166
                Ian Gardner
                  @iangardner62867
                  Bob-just had a go and it does look like 0 .7mm- I think the fine thread is 0.5mm pitch. Should have tried that in the first place! I'll go for it.
                  Thanks again.
                  Edited By Ian Gardner on 20/05/2013 10:03:14
                  #41168
                  Ian Gardner
                    @iangardner62867
                    Thank you Tony! That's got to be it. I was sailing Silver Mist on Sunday- my favourite at the moment-except for the noise of the gearbox, so I determined there and then to change the reduction to pulleys and an O ring, which should be quieter.
                    Tony, our last posts crossed I think.
                    Thanks all, for the help
                    Edited By Ian Gardner on 20/05/2013 11:32:38
                    #41178
                    David Marks 2
                      @davidmarks2
                      The convention used on Engineeering Drawings for metric threads is where the standard (coarse) thread is required, just the nominal size is defined e.g. M10 (which has a pitch of 1.5 mm). Where a finer thread is required, then the nominal size + the pitch are defined e.g. M10 X 1.25. For any metric thread, (due to a fluke of geometry) the diameter of the tapping can be calculated by subtracting the pitch from the nominal diameter e.g. for a M10 X 1.25 thread, the tapping drill required is 8.75 mm.
                      #41194
                      Ian Gardner
                        @iangardner62867
                        Thank you David, for that useful information, which supports the idea that the course thread is the default.
                        Interesting about the tapping drill size too- I knew folk on here would come up trumps- always worth asking!
