LOCH TORRIDON
LOCH TORRIDON
Home Forums Scratch build LOCH TORRIDON
  • #22381
      Loch Torridon 1881 – 1915
          Bob, my ghast is well and truly flabbered at all that rigging. Fantastic job.I have to steel myself before installing a whip ariel, me    ashley
          #22386
          Barry Foote
            @barryfoote68385
            Superb as usual Bob…
            #22397
              Thanks,
              This what I call rigging though!
                Both very nice models, Bob……………….Especially the Pruessian ship……….(I know it`s miss-spelt)
                The sails are beautifully uniform…….thanks to CAD no doubt!
                  Hi Bob,
                  Thanks,
                  The sails on PREUSSEN were made from white airmail paper moulded around an ostrich egg whilst wet to get the wind-filled shape.   The grey sail seams were pre-printed on both side of the paper with the computer printer before I moulded them    The sails were edged in fine copper wire.
                  I have heard modellers talk about CAD, but it sounds far too complicated for me.    I could probably master it, but I have little patience for that sort of thing and am not really sure what it does anyway!
                  It is all fingerwork apart from cutting the big pieces with a hobby bandsaw,  making the round parts on a small lathe and using a hand-held 12 Volt drill from time to time.    Scalpel and  tweezers were my main tools.
                    Hello Bob
                    Cad stands for “Computer Aided Design” and is very useful.
                    I inherited the program from my working days………It`s very easy once you know how!
                    For instance, you could have drawn all your sails on the pc…….with all the lines and fillets and eyes etc and any fancy pattern etc and printed them out…in any colour too!…………….all the correct size and identical
                    I used this system for the cabins on my Great Eastern……………….I needed 24 identical skylights……………….hence the CAD approach
                    Anyway…………………What will you create next?………………A little Louis Heloise might be suitable?
                      All the sails on the PREUSSEN were different and individual.    A lower topsail on the foremast was different to corresponding sail on main, middle, mizzen or jigger .       Neither were they correctly shaped according to the sail plan.    I had problems for years with setting sails correctly.   It was only when I finally realised that a wind-filled sail is pulled completely out of shape by the wind that I was able to set them correctly.     I really can’t see any way of improving on the old ostrich egg with its multiple curves.
                      Apart from that, everyone I know who messes about with CAD tells me it is very complicated and time-consuming and, more importantly, none of them have actually produced anything from CAD that I can appreciate.    And it is horribly expensive as well!
                      I know all this may sound a bit negative and make me look like a dinasour, but after a lifetime career in electronics, I came to detest progress with transistors, ICs, and high technology, satellites, firbre optics, micro-electronics  in general.      I only mastered computers because it is now  a case of “ignore them at your peril!”    In late 1992, I chucked in my job as senior communications officer  (technical as well as operating)aboard the British passenger liner RMS ST. HELENA  (completed 1990).    Just couldn’t stand it any more.     I have now reverted to “dinasour” status with knife and tweezers.    I never even build models of ships that were completed after about 1965!
                      At present, I am building Royal Mail Lines DESEADO of 1961 and that is rather a bit too modern for my liking!
                      Never even heard of Louis Heloise!
                      At the same time, I haven’t the slightest interest in ship built before about 1840 (the age of the camera)
                        This is Loius Heloise, built about 1900…..(guessing)
                        #22418
                          Hi Bob,
                          Nice looking vessel, but a bit too small for me.    I don’t mean the physical size of the model, I mean the actual ship.   I really prefer the big iron & steel square-riggers when it comes to sail, but I suppose I build more steamers and motorships than anything else.
                          Can’t really see how CAD would help me in any way.   All I have ever seen it do is produce plans, but I have the plans of what I build anyway!
