LiPo battery advice
LiPo battery advice
Home › Forums › R/C & Accessories › LiPo battery advice
  • #61400
    rob smith 4
      @robsmith4
      I have a 49" grp hulled perkasa that i plan to use the following motor and esc in
      http://www.componentshop.co.uk/60a-marine-v3-waterproof-brushless-motor-speed-controller-esc.html
      http://www.componentshop.co.uk/lc4250-5t-960kv-leopard-outrunner-brushless-motor.html
      I also have a LiPo battery ( that is for a high power / high drain spotlight) the spec as follows
      11.1v 9200mah
      sizes in mm approx 110x80x30 weight approx 530g
      would this battery be suitable to run the above motor ? bearing in mind that I don't know how many cells it is made from ( though I could find out)
      Thanks
      #5393
      rob smith 4
        @robsmith4
        can i use this ?
        #61404
          Hi Rob
          The ESC only 60Amps and that motor specs requires 75Amps, so, go to a 100 Amp ESC to be safe.
          The battery is 3 cell (11.1 volts), 4cell(14.8 volts), 5 cell(18.5 volts) and 6 cell(22.5 volts).
          #61405
            Hi Rob
            What is the estimated weight of the completed model?
            rob smith 4
              @robsmith4
              hI Paul as yet I have no idea.
              Its an unstarted kit at present. I do plan to reduce weight as much as poss by replacing the upper woodwork but that depends on the motor / battery etc.
              Harry – so it seems it would be ok with a bigger esc ?
              and thanks
              #61409
                Rob
                2 x PM's sent. Ignore the first one!!
                Edited By Dave Milbourn on 14/11/2015 11:14:09
                #61415
                rob smith 4
                  @robsmith4
                  Nice one dave. I'll order that one wink
