Leopard 1050kv motor linkage
Home Forums Beginners Leopard 1050kv motor linkage
  • #2627
    Robin Bodger
      @robinbodger80379
      #68292
      Robin Bodger
        @robinbodger80379
        Hi all, got my leopard 1050kv motor, when I link this to the prop shaft I am assuming I remove all the end play from the prop end and using threaded uv joint, and set said motor back so any exposed drive shaft is visible inside the boat? Do I have to shim up the driveshaft to take up any end play in the shaft? Any picture or digram would be much appreciated!
        #68294
          Robin
          One washer between the back of the prop and the end of the tube is regulation – some fit an additional PTFE or nylon one, but no more than that.
          The usual Huco-type universal coupling isn't really adequate for brushless motors and frequently they are badly-made and vibrate like fun at even moderate speeds. I run the Leopard 2826/17T 1050kv in one of my models and have finally settled on SHG's Mini flexible couplings (Page 20 of their catalogue).
          They are expensive but they are strong and well-made. If you want to contact them the best way is by phone; Jerome is notorious for allowing E-Mails to go wide!
          Robin Bodger
            @robinbodger80379
            So the coupling to the motor holds the drive shaft up against the bush at the prop end? Will give shg a call anyway, ta m8.
            #68300
              Yes (I think…).
                Prop and coupler both need to be fixed so that neither can move without you using a spanner on it – locknuts AND thread locking compound are both good. A prop unwinding itself is deeply annoying. So is a prop that manages to tighten itself up, because then it acts like a very effective brake. The usual follow-up question is along the lines of "Why has my motor/esc/wiring let the magic smoke out?"
                Yes you need thrust washers to stop either end wearing the prop shaft bush faces or the prop or coupler face. When going forward, the prop is pushing the outer bearing forward, n reverse, it tries to pull the shaft out of the boat.
                You don't want threaded bits of shaft inside the bearings.
                No end load should be transmitted to the motor. The motor bearings are not usually designed to cope with that, they just stop the inside bits from wobbling about and allow the motor to turn.
                #68374
                Robin Bodger
                  @robinbodger80379
                  Ah, just discovered their is meant to be a grub screw collar at the motor end to hold the drive shaft in place. That explains allot.
