Leaking hull
Leaking hull
Home › Forums › Beginners › Leaking hull
  • #72625
    Peter Brown 15
      @peterbrown15
      Hi just bath tested my boat and after about 5 mins noticed water in one area of the boat about midship. No leaks from the prop or rudder. Is the solution to stand down the hull fill if any gaps found or use a fibreglass resin?
      #2701
      Peter Brown 15
        @peterbrown15
        In old wooden Vosper
        #72626
        Dodgy Geezer 1
          @dodgygeezer1
          First step is to find the leak. Try drying out the hull, puffing a bit of talcum powder in and looking to see where the leak develops first…
          #72627
          Peter Brown 15
            @peterbrown15
            Thinking about stripping the old paint off, sanding and filling the seams with expoxy resin. Not sure if this is the standard epoxy mixing tubes A & B or is it specialist stuff?
            #72628
            Dodgy Geezer 1
              @dodgygeezer1
              Gaps can be hard to spot, and may not be on a seam. Really, you are better off to find out precisely where the problem is before undertaking a large amount of work…
              #72629
              Peter Brown 15
                @peterbrown15
                Just had another look and there are gaps in the seams. What’s the best option for this.
                #72630
                Charles Oates
                  @charlesoates31738
                  Here is one option, other approaches are just as valid. Sand or strip most of the paint off. Check all the joints and seams, any loose joints and unsupported planks / skins should be attended to. Minor gaps can be filled with plastic padding elastic, or similar, it's easy to sand but not a glue substitute. Then paint the inside with a polyester / fibreglass resin, it waterproofs and stabilises the hull. Then re paint the hull and all should be fine. It is my opinion that quick fixes lead to trouble later. Don't be afraid to add or substitute wood in suspect areas, fillers and resin aren't a substitute for good building..
                  Chas.
                  #72631
                    Peter
                    There is only one way to do this properly, strip off all the paint and get down to bare wood then you can investigate every joint and seam, there is a good chance that the original glue could have deteriorated and you might have a complete re-glue on your hands.
                    This isn't as daunting as it sounds as it can be done in short sections.
                    Hopefully your problem isn't so bad.
                    Dodgy Geezer 1
                      @dodgygeezer1
                      If you use a resin like Z-Poxy, which is intended for painting on, it should creep into the gaps in the seams and glue/seal them effectively. A coat inside and outside would certainly make the boat watertight…
                      Edited By Dodgy Geezer on 14/08/2017 18:25:17
                      #72752
                      soleyjon
                        @soleyjon
                        Morning, If It was mine I'd start on the inside, food colouring in plain water, mix well- pour into hull! you should see where the gap/s are , dry it all out, it's got wet inside anyway..! thin epoxy resin like DG says pour in where the leak is and leave to set, he quicker the better…job done.
                        SJ.
                        #73068
                        Queequeg Quint
                          @queequegquint38270
                          My Orca boat is made of planked wood. I didn't make the hull itself, but the bloke who did said it was sealed. On my first run, it began to sink!
                          So, I sanded off all the paint and then began to apply several layers of fiberglass resin and fiberglass cloth. I did this on the entire outside of the boat. Then, I applied a layer inside the hull. Finally, I applied a line of adhesive sealant along both sides of the keel on the inside. All told, I have about 7 layers of fiberglass resin and cloth on the outside. No more leaks! The only water that gets in is from the splashing water.
                          This hull is so strong now, I can actually drop the hull on the ground and it won't break!
                          Edited By Queequeg Quint on 07/09/2017 02:43:57
