Italeria e boat
Italeria e boat
Home › Forums › All things floating › Italeria e boat
  • #41138
    Andy Hustler
      @andyhustler32076
      can i pick up spaeres for my e boat and woild i get away wth brass stanchion railss all round
      Many thanks
      Andy from Cardiff
      #3987
      Andy Hustler
        @andyhustler32076
        #41140
          Andy geezer.. you are not making much sense there…
          Brass stanchion rails would certainly work…but why "get away with??" brass stanchions are pretty much standard fare. Doesnt the kit come with stanchions??
          OR is it this that you need the spares for????
          Ashley.
          #41158
          Andy Hustler
            @andyhustler32076
            Sorry ashley long hours over the past few days 26 hours in work out of 48 !!!! .The kit does come with stanchions but i dont go much for them as they are plastic and not very well moulded . I could do with the stanchions that are a solid railing set and maybe the torpedo's but i guess i can knock them up out of some dowel .Again many thanks for taking the time to reply
            Andy
            #41160
              Andy. Knocking some torpedoes up, preferably in balsa, may be a good move in any event to relieve top-weight!
              How big are the stanchions.. could you make your own..brass rod and wire…soldered together over a former (wood , carefull drawn lines and small panel pins??
              Andy Hustler
                @andyhustler32076
                Ashley i do like your idea of soldering but i would rather use the stanchions as my soldering is not that tidy and would probably sink the boat !!!!! Speaking of stanchions my local shop , antics, are having dificulties with suppliers so any ideas on other shops or just look about the net
                #41230
                LARRY WHETTON
                  @larrywhetton68737
                  Hello Andy,
                  Try James Lane
                  Display models
                  30, broadway
                  BLYTH
                  northumbland
                  NE24 2PP.
                  He is not on the web so phone for info and cattologe,    phone no.. 01670 352051…
                  first class service and product .
                  hope this helps Larry…………
                  Edited By LARRY WHETTON on 22/05/2013 09:49:02
                  #41413
                  ojays
                    @ojays
                    I got mine from Fea-bay (Robbe 1510 Railing Stanchion 25mm) in packets of 10.
                    You will need 4 packs for the Boote.and I used brass rod and cable for the railings etc.
                    Gregg
                    Edited By ojays on 04/06/2013 22:30:38
