Bob. Amazing, truly amazing.
Phil. You are not alone in dragging on a build! I always find that the big bits (Hull, running gear. superstructure) whizz along and then you either stall on something fiddly or the grind of all the little things gets to you and the work slows….
I try to make it a point not to sail anything before its finished (apart form the usual bath test) as, as soon as its in the water..in my minds eye it is done, and I start something else!!|
