Graupner True Blue Yacht
Home Forums All things floating Graupner True Blue Yacht
  • #66661
    Peter Morris 5
      @petermorris5
      HELP!! Does anyone know where I can get a keel bulb for a True Blue to replace mine that is now under 10 feet of water?
      #4343
      Peter Morris 5
        @petermorris5
        #66662
          You might need to get inventive and use a spare for a Monsoon or similar – the cases are listed as available and not expensive – "just" need filling with lead shot.
          #66692
            Hi Peter
            I'm just going to Wickes to buy a roll of lead flashing to cast a keel weight for my latest project, have you thought about casting a replacement all you need is a wooden pattern and some plaster of paris for a mould, but depends on knowing the size & weight of the one that dropped off ?
            Best Regards Ray
            #66693
            Peter Morris 5
              @petermorris5
              Thanks Ray but I have now modified an unidentified but similar sized fin and keel that I had in my 'spares box'. Will be interested to talk about casting next time we meet though!
              #66694
              Peter Morris 5
                @petermorris5
                Thanks Malcolm, the Monsoon keel bulb might well be a solution if I can now find somewhere to buy one!!
